Go to Post I don't think we really fit into those rigidly defined categories, my team builds our robot. - AdamHeard [more]
Unread 16-06-2003, 22:52
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Heat Sink habit
Originally posted by Jay05
Basically I crimp the hell out of the connector and then shrink a 5 inch piece over the connector and wire. Is this common practice for anyone else?
Like Sanddrag said, it's not really a good idea to "overcrimp" the connectors on to the wire. You're much better off crimping the wires normally and then soldering the connection. I can't emphasize enough how worthwhile it is to spend the minute or two soldering each connection on your robot. If you need removable connections like in this case, then solder the connector to the wire. For connections that don't need to be taken apart, just twist the wires together and solder that (don't forget to slide some loose heatshrink on the wire first to pull over the connection after it's soldered!) Heatshrinking over the connectors is always a good idea too.
'IT' info... archiver 2001 19 24-06-2002 01:58
Team heat wave is on fire!!!!!!!!!!!!! archiver 2001 3 24-06-2002 01:38
heat sinks archiver 2000 1 23-06-2002 22:45
New IT info? Mike Soukup Dean Kamen's Inventions 10 08-12-2001 23:03
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
