Go to Post Also, I did not know that Autodesk had changed our name from WildStang to "Digital Cheetanators"? - Raul [more]
Unread 17-06-2003, 00:03
Lisa Rodriguez Lisa Rodriguez is offline
Biology Grad Student.....
AKA: Lisa Rodriguez
FRC #0173 (RAGE)
Lisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant future
Send a message via AIM to Lisa Rodriguez Send a message via MSN to Lisa Rodriguez
Telephone wiring
hey, Ogre under my sister's name again.
Question about telephone wiring. I have done some minor research about how to put in a phone jack. My biggest problem is that our house has like 10 wires, a blue and white with blue stripes, red and white with red stripes, brown and white with brown stripes, grey and white with grey stripes, and green and white with green stripes. The phone line, i'm pretty sure, uses the blue and white with blue stripes. I took apart a working line and thats what it used, but when i hooked up my own, the whole line went dead.
On the current jack, the blue goes to two wires and the striped goes to two wires. I know it matters what wires they go to, but of the two that each uses, does it matter which end goes to where.
If thats hard to understand then try this:
currently
Blue wire == red wire
Blue wire == black wire
Striped wire == yellow wire
striped wire == green wire
would it matter if went like this.
Striped wire == green wire
striped wire == yellow wire
also, can the other wires, assuming they're not in use, be used as Cat5 wires, or are they not fast enough?
Any info you have would be great, thanks.
This thing still works?
it's never over unless you let it be over
Unread 17-06-2003, 07:43
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
well, not cat5, maybe cat3...
depends on the quality of the wires and how they're arranged. the arrangement in a UTP CAT5 cable is in twisted pairs. if theyr'e arranged differently it could cause interference and quality degredation, slowing it down cause more packets are lost.
We were the first seeded first-year team at a first-year FIRST regional.
Unread 17-06-2003, 18:07
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Usually telephone lines are the red and green wires for the signal. In older homes you'll find the black and yellow wires which were used as a power source from the central office. This system is no longer used anymore so you can do as you wish with them.
Check your telco box outdoors (usually there's a standard screw on the user-accessible section) and check which wires in your house are being used. It shouldn't hurt to use the unused wires for an ethernet connection. You'll need two of the twisted pairs for it to work though. Usually it's the green/green-striped and orange/orange-striped pairs.
Then, you'll need some connectors and a Cat5 crimping tool (these things cost $40 so borrow one if you can. Put the wires in the proper pins (guide: here). All the one's that say N/A don't hook up. You only need those four for an ethernet connection to work.
The negative side is, you're not going to be able to hook more than two computers up to such a network. In the page above, use the wiring diagram for B on one crimp, and A for the other crimp.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 17-06-2003, 22:16
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Since not having each pairs twisted causes data loss, is it een worth attempting this project?
The wires in the house are not twisted on pairs, but more in a bunch. Would I lose alot of data this way?
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 18-06-2003, 00:22
AlbertW's Avatar
AKA: Aonic
well, its not that not having twisted pairs causes data loss, its just that having them in twisted pairs minimizes interference.
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
wiring. archiver 2001 1 24-06-2002 00:07
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
What is the wiring for the FESTO valve? Nuts4FIRST Technical Discussion 4 12-02-2002 17:14
