Go to Post Having someone with as much mainstream appeal as will.i.am is a great strategy to draw large amounts of attention to a program that has been relatively hidden to the masses. - Karthik [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 11-06-2003, 18:44
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
To all you Websever-At-Home people out there...
As you can see, I am in a delima.
I was wondering if there is a way to setup a public websever, behind a Linksys router.
If not, then how do you convince Comcast to let you have 2 cable modems?
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 11-06-2003, 18:55
Happy Birthday! rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
It's actually fairly easy. There's two ways of doing it:
1. Tell your router to forward all traffic to port 80 to your computer. This is referrred to as port forwarding or just plain forwarding.
2. Tell your router to forward ALL incoming traffic to your computer. Linksys often calls this option a DMZ host.
On my linksys, both these options are found in the advanced section of the web-based config utility.
--Rob
Unread 11-06-2003, 19:06
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
ahh... just though i'd point this out to you:
from http://www.comcast.net/terms/use.jsp
You may not run a server in connection with the Service, nor may you provide network services to others via the Service unless you are subject to a Service plan that permits otherwise. Examples of prohibited uses include, but are not limited to, running servers for mail, http, ftp, irc, wifi, and dhcp, and multi-user interactive forums
Now, I'm not really sure exactly what plan you have and if is does allow a webserver. Just though I'd remind you of that little fact though.
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 11-06-2003, 19:27
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
That thing Jack just quoted basically means you can't have more than 1 computer. I know with Road Runner you need to pay for each computer hooked up to the connectiong. Personally we have an open WiFi network, run iRC servers, have a webserver, dhcp, and have 4 computers hooked up..
Oops!
Just setup: FoxServ (http://sourceforge.net/projects/foxserv) and then access it via localhost.. that should work..
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 11-06-2003, 19:35
Jack's Avatar
AKA: Andrew Schenk
Originally posted by AJ Quick
[b]That thing Jack just quoted basically means you can't have more than 1 computer.
Um.. no, not really..
While comcast would most likely never find out unless you were running some major web server, their tos says that: (paraphrased)
You may not use their service (the cable internet) to provide a service to others (another internet user) such as http (webserver).
But... yes.. you are correct. I'm sure somewhere else it also mentions that you can only connect one computer.
Unread 11-06-2003, 19:47
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
I just read WOW's TOS, and it basically states the same thing. But Jack is right.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 11-06-2003, 20:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A lot of people do run webservers anyways even when their ISPs say not to. It's just because your ISP does not have the bandwidth for you that they tell you that they give you. If you took everyone's max allowed bandwidth and added it up it would be way more than what the ISP's total allowed bandwidth is. They just can't have everyone with their service runing web-servers. That's the main reason they say no.
Now, is it okay? No. Could you do it anyway? Probably so.
However, you need some good firewall protection and security because running a webserver will put your whole home network at risk for hacking. People could try to use it to distrubute illegal music and videos or use it in a denial of service attack.
It's really worth it to just pay around 50 bucks a year (or possibly less or more) for some hosting that's got what you want.
If you do run your own, be careful.
Here's a good link about home webservers http://www.dslwebserver.com
Unread 11-06-2003, 20:06
AKA: Eric Hansen
You got protection if you run Apache and just allowing http://localhost
Y!: synsoflife
Unread 11-06-2003, 20:10
Actually, RR is one of the more lenient companies when it comes to this sort of stuff. At least here in Minneapolis, they don't care (heck, they recomend linksys routers to people) how many computers are hooked up to a single connection; the only time they charge you more is if they put in a second cable modem so you don't have to setup a network.
They do, however, care about running servers. Last time I checked, running a server was cause for cancelling service without any warning or refund.
I personally don't risk it, except very occasionally when I put up a few files so I can access them at school.
Unread 13-06-2003, 01:39
AJ Quick's Avatar
Yeah, I was referring to what ComCast had set up in their TOS. I know when I was looking into free dial up from RR, I read that you need to pay like 10 dollars for every IP you have hooked up. So, yes you would be correct about that... I was thinking they would still charge you for using a router to do the same thing without the extra IPs.
This is kinda getting OT now, sorry LBK! Did you find anyone that can help? I know I've tried using this script before, and I've never gotten it to work.. I think its the code.. Has my friends phpBB modding site been any help to you?
Unread 13-06-2003, 02:08
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Check out http://www.dslreports.com . (They also report on cable connections.)
About a year ago, I was able to find a local company that offered dsl with a static ip address, and I didn't see anything prohibiting the running of a server. (Of course it could have be buried somewhere in their sign up agreements. However our school recently signed up with them because they offer static IP addresses.) There were some other frills that they didn't give you: no free dial up service if you were away, and no hosting for a small web site. That company is local to S. Calif. but there should be something similar in other areas.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 13-06-2003, 02:18
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
1. They restrict providing service to other individuals. You can still provide the service to your own computers.
2. They probabaly aren't charging for the computers, they're charging for the IP address. There are only a limited number of IP addresses for the world to use under the current system, so they cost $$$. Home LAN systems help eliminate this, so most providers don't care.
3. As for servers, in general, don't do it. If you start to generate a lot of traffic (and INet providers do monitor this, because it costs them more $$$ to upload than download) then that's a bad signal. They will begin monitoring your traffic and catch on to you. A lot of internet providers generate income by offering web hosting services. They don't want you doing your own and profiting.
I don't want to rain on your parade, so I'll still tell you how to do it.
First, you need to have your Linksys router forward all traffic on port 80 to your computer (see manual: Port Forwarding). This address is most likely 192.168.0.2 unless you configured your network differently. Go to the command prompt and type ipconfig to determine this.
Next, you need a web service program. If you want free, use Analog X's SimpleServer. It's easy to use and supports CGI and PHP (I believe). Otherwise, you can look what's at Download.com or use a Linux webserver.
Lastly, you'll want a hostname for your computer, you can use various services like DynDNS so you don't have to give people your IP address all the time (especially if it changes a lot). These services run on your computer and it sends your IP address to DynDNS, who then associates it with http://yourname.dyndns.org.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 18-06-2003, 11:17
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
If it's illegal, then I won't do it. (I don't want to go to prison for just a websever)
Thanks for the TOS. I couldn't have found that if my life depened on it.
Now, for those of you who do have written permetion to host a websever, how did you write up the letter?
Or mabe, you'll can tell me how to dump an ISP and go straight to the internet. (If you know how, pleeeaaase tell me how)
Anthony Rinaldi
Team 1132: 2003
Unread 18-06-2003, 18:50
You will not go to prison unless you are distributing sertain types of material through your server. Your ISP may cancel service without notice and never let you come back and perhaps fine you. That's about the worst that could really happen.
Unread 23-06-2003, 14:45
HFWang's Avatar
HFWang HFWang is offline
AKA: DarkWulf
#0115
Team Role: Webmaster
HFWang will become famous soon enough
Send a message via ICQ to HFWang Send a message via AIM to HFWang
apache/mysql/php are suprisingly easy to install.
i think apache comes with an installer, and ditto for mysql. adding in php involved moving like two files and then adding (*quickly counts*) two line to my apache configuration file.
so if you want to just try it out, it is seriously easy to just do it yourself.
How many people stayed home from school today? Alaina Chit-Chat 15 15-04-2003 20:55
need help in meeting people in National archiver 2001 9 24-06-2002 02:33
Mountain Home & 'The Brawl' archiver 2000 0 23-06-2002 23:20
Losing focus on the purpose of FIRST.. someone bring me back archiver 2000 6 23-06-2002 22:56
