Go to Post Differentiating based on any superficial criteria (gender, race, or other demographic) only serves to reinforce the false idea that they matter. - JamesCH95 [more]
Unread 28-06-2003, 12:50
D.Fahringer's Avatar
D.Fahringer D.Fahringer is offline
Engineering Tech
FRC #0122 (NASA Knights)
D.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of light
It's going to be easier to balance something with a higher CG
So it would be easier to balance a machine with the rider standing over the wheel axles than under the axles? Hmmm...
A pendulum platform stabilizes at least some of the weight it is supporting, of course the overall CG is very much above the axles. It does this naturally and should require less power from the motors to keep a rider upright. In an inverted pendulum base all weight is in an inverted pendulum status and all of it requires stabilization.
The following example shows two yard sticks one supported at its end the other also supported at its end (superglued) but it is nested in a balsa pendulum.
Any difference between the two?
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
