Go to Post Yes, it really is Bill Miller posting on Chief Delphi (Imagine that!). - Bill Miller [more]
Unread 01-02-2002, 10:24
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
How about a slot directive?
It might be nice to have a slot directive that allows you to start the code for a different programming slot in the same file.
Typical directives:
To start a new slot (slot number assigned by the preprossor -- we refernence them by name):
{$SlotStart slotname}
To end a slot (perhaps not required, either the file ends or a new slot begins:
{$SlotEnd}
To run another slot (preprocessor resolves the slotname to the required number)
{Run slotname}
Along with this I would say it would be nice to have "global" include directives and "local" include directives.
This would let us have some code (say the declarations of variables, constants, etc.) included in all programming slots and then but then we could include special code in specific programming slots.
I know I am asking a lot, but you asked for feedback.
Joe J.
Unread 01-02-2002, 11:36
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Label Example
Originally posted by GreenDice
Greg,
Could you give some examples on how to use labels?
Thanks.
Sure. Sorry for the oversight.
AppleTest:      {$if X = Apple}
                  debug "X is an apple", cr
OrangeTest:     {$elseif X = Orange}
                  debug "X is an orange", cr
MangoTest:      {$elseif X = Mango}
                  debug "X is an mango", cr
NoneOfTheAbove: {$else}
                  debug "X must be a banana", cr
EndFruitTest:   {$endif}
Unread 01-02-2002, 11:50
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Re: How about a slot directive?
Typical directives:
{$SlotEnd}
{Run slotname}
I think I like it. Let me stew on it a bit.
If I'm understanding what you need, then you can already do this with multiple include files. You're not restricted to a single $Include directive per file. Simply $Include the global data file in all your project files, and $Include the special code files only where you need them.
Joe J.
Yes, I did, and I appreciate it all.
Unread 12-02-2002, 14:53
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
How about another preprocessor directive?
I'm thinking about adding another directive similar to the $Slot directive suggested by Dr. Joe.
$Slot demarks a section of a preprocessor source file to be output as a separate BASIC Stamp program which is loaded into one of the suplemental program slots.
The new directive would identify a portion of a file which can be $Included in any of your $Slot output files.
I'm proposing $IncludeSource for the directive name. The syntax would be {$IncludeSource symbolic_name}. The source file lines between the $IncludeSource and a subsequent $EndIncludeSource directive can then be $Included using symbolic_name.
Example:
{$Stamp bs2sx}
{$IncludeSource dataIncludes}
' Your data definitions go here
{$EndIncludeSource}
{$Include dataIncludes} ' Insert the data definitions from above
'Your program initialization goes here
'Now run the main control loop
{$Run MainLoop}
{$Slot MainLoop}
' Read inputs and process them
'When you run out of program space, split your program, and
'continue in the next program slot.
{$Run NextSlot}
{$Slot NextSlot}
'Do some more processing...
'Finally, output your data via the serout command, and go back to
'the beginning of the control loop.
serout ...
{$Run MainLoop}
Unread 16-02-2002, 22:14
GhettoTech GhettoTech is offline
#0300 (Ghetto Techs)
GhettoTech is an unknown quantity at this point
Send a message via AIM to GhettoTech
From my understanding of the original posted question, you want to avoid typing multiple "IF" statements.
http://parallaxinc.com/downloads/Doc...ual%20v2.0.pdf
That's a link to the manual for the Basic Stamp, look up the "Branch" code. (Pages 85 & 86)
~Excerpt from Basic Stamp Manual~
[b]Explanation:[\B]
The BRANCH instruction is useful when you want to write something like this:
IF value = 0 THEN case_0 ' value =0: go to label "case_0"
IF value = 1 THEN case_1 ' value =1: go to label "case_1"
IF value = 2 THEN case_2 ' value =2: go to label "case_2"
You can use BRANCH to organize this into a single statement:
BRANCH value, [case_0, case_1, case_2]
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
emulationFIRST (aka PBasic emulator) Matt Leese Programming 5 30-06-2002 12:06
PBASIC Loop Speed? archiver 2001 3 23-06-2002 23:46
