Go to Post One of my early mentors gave me wise words -- when designing a system to compile & analyze information, your first design choice should always include consideration of a stack of 3x5 file cards. - Jaxom [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
View Poll Results: What resolution do you view ChiefDelphi.com at?
640x480 1 1.96%
800x600 12 23.53%
1024x768 20 39.22%
1152x864 3 5.88%
1280x1024 10 19.61%
1600x1200 4 7.84%
not sure... 1 1.96%
Voters: 51. You may not vote on this poll
Unread 26-06-2001, 10:27
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Question Resolution...
I may change the navigation in the upper right if enough people answer what I want to hear...
Brandon Martus
e-mail
Unread 26-06-2001, 12:05
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
I use 1280x1024. I turn on the favorites button on the browser and for the "White Papers" link, "Papers" wraps under "White". Just thought I'd let you know.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 26-06-2001, 12:08
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
If I remember correctly, I believe it's a generic rule of thumb to design a page to require no more than 800x600 resolution. But it's also a good idea to support 640x480. It doesn't have to look perfect in those cases, but should still be usable.
And you should really validate and fix some of the HTML....
Matt
Unread 26-06-2001, 12:23
busy.
AKA: B. Slash Kamen
yea, i know its not all valid html, but this is a 3rd party software package, and when they release an upgrade, i have to manually fix everything ive changed over again. its already a tedious job with the few hacks ive put into it so far
what html have you found that needs 'fixing'.. point some out, and ill fix it...
the forums are made to fill your screen, no matter what resolution you run at, however when you get down to 800x600 i noticed, all of the links at the top right wrap (but i have a plan to fix that, i was just wondering what resolution everyone was running at)
Brandon Martus
e-mail
Unread 26-06-2001, 13:16
Joel J's Avatar
Joel J Joel J is offline
do you..
Post ....
Originally posted by Brandon Martus
...i have to manually fix everything ive changed over again. its already a tedious job with the few hacks ive put into it so far...
That is why you should download all the templates you edit. Updates usually tell you which templates have been changed, and if it turns out that you edited a template that has been changed, you manually re-edit that template, otherwise you can just upload the one you have saved.....sounds plausible, eh?
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 26-06-2001, 13:21
busy.
AKA: B. Slash Kamen
well templates arent the big problem
but im just saying in general, any functionality hacks usually take a little while to put back in...
Brandon Martus
e-mail
Unread 26-06-2001, 20:52
A Legacy of Impact
That pull down menu fixed the word wrapping problem
2010 Championships
Unread 27-06-2001, 08:06
Take a look at this:
http://validator.w3.org/check?uri=ht...1+Transitional
That should give you an idea what needs to be fixed. And that's just on the main page (http://www.chiefdelphi.com/). For one thing, nothing at CD has a <!DOCTYPE> declaration. I'm assuming you want it to be HTML 4.01 Transitional but that's only my best guess. Taking some time to validate it means that it's more likely to work on other broswers. Also it's just a good idea in general.
Matt
Unread 07-07-2001, 13:45
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Use HTML as Percentage
Try not to use specific resolutions.
To me you have a couple of options.
1.
If you look @
http://www.apple.com/
You can see its upper bar. It is a bunch of gif's lined up in a table. The gifs have one right next to the other one. And from the first tab to the last tab is 640 by width. Then they have an extra gif on the side
which is called
http://a772.g.akamai.net/7/772/51/55...s/en/i/1bg.gif
This gif looks vert small, but it repeated becuase it is in the background of a table. So @ any resolution beyond 640x480 then it would be a nice little extra border that will extend anything beyond 640x480 to whatever resulution.
This is probably the best option beauce it is the easiest and so may people have so many different reolutions.
My monitor for example has really weird resolutions because it is a 19" that is in a rectangualar format. So I have reosolutions like
832x624
1024x768
1152x870
all the way to
1920x1080
The other way to do is a much more complicated java sript option that calculates the image sizes, table sizes, form sizes, etc. by getting the users resolution via javascript and increasing the size of the tables, images, and pictures, by multiply it by a specific ammount to whatever the size is.
However this has some drawbacks the webmaster has to predefine how much to mutiply for each resolution, so if there is a weird resolution than it may come out weird. Also some browsers liek IE and Netscape has different looks, and it may come out even weider.
They are probably other options, but it is a difficult issue as a website designer.
Unread 15-05-2002, 18:49
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
1600x1200 is the best resolution ever (excluding any higher than it)
Follow me on twitter @roboticsrob and my FTC team @griffins10092
White Paper Discuss: Increasing A/D Resolution Using Noise CD47-Bot Extra Discussion 7 12-10-2004 09:26
What resolution do you use on your monitor? Elgin Clock IT / Communications 29 17-02-2004 22:10
DNS resolution mixup. evulish CD Forum Support 2 14-11-2002 23:40
QUESTION OF THE YEAR!!! archiver 2001 8 23-06-2002 22:14
High resolution FIRST logo thedillybar General Forum 4 16-03-2002 19:09
