Go to Post I got Vista with mine. It's like getting moldy fruitcake for Christmas. - Koko Ed [more]
Unread 01-02-2002, 14:59
AWiser's Avatar
AWiser AWiser is offline
AWiser is an unknown quantity at this point
Send a message via AIM to AWiser Send a message via Yahoo to AWiser
Light Specs
Does anyone know where I can get specs on the light? I need to know the diameter, how it mounts, what the mounting looks like, and (if it uses screws to hold it to a base) the thickness of the mounting and the diameter/size of the screw holes. Thanks!
~Alex Wiser~ <Team #846 (Lynbrook)>
There are three kinds of people in the world:
Those who can count...
and those who can't
Unread 01-02-2002, 15:32
Neill Means Neill Means is offline
#0933 (Sallgood)
Neill Means is an unknown quantity at this point
Me too! How about weight too???
Unread 01-02-2002, 15:35
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Weight is posted elsewhere...
1.45 lbs according to those in the know...
Joe J.
Unread 01-02-2002, 20:55
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
If you take a look at our last year robot http://www.gforcerobotics.com/robot/Pict7.html you will see a fairly close up of the light. For sizing you can use the aluminum frame tubing. It is 1" square.
On the bottom of the light are two studs. One positive and one negative. I don't know what the spacing is.
Also you must mount the light to a non-conductive base. We used 1/8" lexan.
Hope this helps.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
light visibility Erinn888 General Forum 30 17-02-2003 15:56
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
