Go to Post Don't test your autonomous on the comp field. There's a practice field for a reason. - DampRobot [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations > FIRST Scouting Network
Unread 11-06-2003, 20:12
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Requirements- Data Access
Well, it seems that in the process of writing the other two questions, I came upon a third. While the first two deal predominantly with the competition-side elements, such as the data collection types and methods, this deals more with the "server-side" elements of the web interface and such.
Without further adue, Question #3: What do you want to see available on the FSN website? How do you want to be able to access the data that is collected? How can FSN best provide access to this data to as many teams as possible, as soon as possible? I'm not looking for technical implementation here, but rather your opinions on the interface, how to use it, and how to make it widely available.
Jeff Waegelin
Unread 12-06-2003, 20:43
John JediMaster's Avatar
John JediMaster John JediMaster is offline
#0019 (Big Red)
John JediMaster is an unknown quantity at this point
Send a message via AIM to John JediMaster
take soap 108's team search, but take it a step further and make it so that you can search by a certain aspect. for instance for this year you could make it so that you could search for a stacker or a pusher, that along with the team. Or add in the awards so scouts would know what teams to scout.
Unread 12-06-2003, 23:12
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Data should be retrieved by any site who can use the XML transport and display it in their own manner. I feel that the site should not have any direct way of viewing the information. There should be XML code that will display a team's info based on what is in the url, like: /xml/team_info?team=6
Then that would deliver XML info to the site that requests it. Sites like Soap would display information as they do now... The network should integrate seamlessly into any FIRST team's website that has the capability. The FSN site shouldn't directly make available any site info on the site.. and leave that up to each individual team.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 12-06-2003, 23:32
Jack's Avatar
Jack Jack is offline
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
hrm.. that is a very intresting idea AJ.
Pros:
  • Truly open up the system & not really have one central location.
  • Would reduce the server load a lot (I think). All it would mostly be doing would be serving the xml or parsing incoming data. No graphics.
  • End users could select the end site which they preferred the most.
Cons:
  • Would make quickly viewing data harder. For new people, there would be lots of sites to view
  • It would mabey be more vauge that a direct one "main" simple site approch.
  • more soon...
It really is an intresting idea... What are other's ideas on it?
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 12-06-2003, 23:41
El Jefe de 148
I told myself I wouldn't respond to my own question, but this seems to call for a response. So, here's my two cents: I think FSN needs to have a central viewing system. Teams should still be able to grab XML from the FSN server and display data on their website, but someone going to the main FSN site should be able to get data there, not just links to teams that are hosting the data. What I think it really comes down to is a decision between having a distributed, loosely affiliated network, and having a centralized system that is shared out to other teams. I think the second option is the most efficient, and we have the resources to implement a central server, so we should.
So, what I propose is a compromise. The FSN site should have its own viewing area. To make this easily accessible to everyone, without having to search for an FSN host site, this is a must. However, any team that wishes to put FSN data on their site should be able to pull down an XML feed, and then display it as they see fit. As I see it, it's the best of both worlds. We don't need to spread FSN out just for the sake of distributing the traffic or bringing visitors to partner teams' sites, but there is definite merit in allowing teams to easily use the FSN data.
Jeff Waegelin
Unread 12-06-2003, 23:42
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
I say have both. Display it on the site, and give other sites the ability to install something (or the documentation to write their own) to show the data.
Brandon Martus
e-mail
Unread 13-06-2003, 01:28
AJ Quick's Avatar
You have to read all 3 of my posts to get an idea of what I was going for. I think it would be ok to view data on the site, maybe only for designated members to make sure things are ok? I just really feel that a central site will take away many things that makes a site good.. (ie Soap) sure they can still display info (and they have videos) but why would anyone end up venturing to their site to check data when they can go to FSN.
I'm looking to get people to become more aware of other teams out there. Such a way of displaying info on a site, or via Palm, PC.. etc.. could make more teams become well known. For example, there would never had been so many visitors to CD this season if FIRST had not directly referred to them.. if FIRST would refer to the FSN as the place to go.. people will go.. but when they see they have to go to other sites maybe they will.. maybe they will check out that site.. and they will become more popular and well known as CD is.
I have been thinking about this for a few months now, but feel like I really suck at communicating what I'm thinking... so if you are confused just ask.. I will try to articulate.
Unread 13-06-2003, 11:30
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
I agree with Brandon.
Make the data available on the FSN site and include search, sort, etc functionality. This way you aren't relying on other teams to create a website to display the data. But of course make the data publically available. If you want this to truely be an open network that serves FIRST as a whole you need to give everyone easy access to the raw data. Then teams can create their own database or PC tools to parse the data at competitions. Hopefully they'll follow the lead of Jack et al and make their tools (and source) available for everyone. Also, if teams make pages that display the data, include links to the pages. Some of us may like their implementation better than the official one.
Mike
Unread 13-06-2003, 14:04
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
I think to make this truely open that i would have to agree with the idea of having it both on the FSN site and also having a raw feed for other teams to access or giving other teams acess to the database itself for searching and that sort of thing.
Also there should be some way to have access to the data offline. IE download things out of the database and have them in a format that could forexample be read with access, excell, or filemaker giving teams without interenet access at competition access to the database, or if thye wanted to they could download it in their hotel rooms the night before and then have it ready for competition the next day.
I also still think it would be cool if we could set up little mini databases at competitions that all the teams who wanted to could tap into and that could possibly access the same info that FIRST has as far as match scores and such go, that way the information at competition could be as current and uptodate as possible.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 01-07-2003, 20:20
Neal Turett Neal Turett is offline
Neal Turett is on a distinguished road
DB Integration
Nothing says that we can't have one main FSN viewpage and still let teams make their own mini-DBs.
If Jack was so kind as to create a MySql account with only SELECT permissions, any team that wanted could log-in and directly pull whatever they wanted to for their own database. Then each's teams programmers could do as they would.
While writing this post, I had the idea of writing a DLL that would allow data from Windows programs and PocketPCs to be easily integrated into the main DBs or team's sub-DB. I'll play with this for a while, and see where it goes.
Unread 03-07-2003, 15:21
Considering my idea with the DLL last night, I realized it was stupid. The public MySql account should allow simple data retrieval, either through a MySql client or a ODBC link.
Data input could be handled through a PHP script and XML upload, allowing for validation and security.
Please excuse yet another of my stupid ideas. It's doable, but why?
Competition Scouting pauluffel Scouting 31 09-01-2003 00:34
Robot Scouting Database archiver 2001 10 24-06-2002 03:00
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
Possible Configuration to keep things cheap archiver 1999 8 23-06-2002 23:03
Distribution of data soap108 Scouting 4 24-12-2001 09:23
