Go to Post Do not under estimate the wood bots and brave little toasters! - hipsterjr [more]
Unread 01-02-2002, 19:36
jnossen jnossen is offline
jnossen is an unknown quantity at this point
Question Dashboard Output Question
I am trying to write a dashboard program in C++(So I can display it on a Palm pilot). What does the dashboard output send out? 1's and 0's or something else.
Unread 01-02-2002, 20:11
The specs for the dashboard port are availible from the innovation first website: http://www.expocard.com/shows/nch021/
It is a serial data stream, The spec shows you which byte is which.
Unread 01-02-2002, 21:48
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
C++ is not the best language for Palms. C++ uses header files and classes which take up lots, let me repeat myself, lots of space, when compared to a normal C program. As long as you have plenty of space, go ahead, but remember, you only have a limited amount of space on a palm. Hope this helps.
Unread 01-02-2002, 22:34
I know that C++ takes up massive amounts of space, but that is what I have a palm compiler for. I'll probably take everything else off the palm when I use it. Thanks for the help though.
Unread 01-02-2002, 22:48
College? What?
No problem, just thought I'd let you know, because another club I'm in at my school wanted to try and program some Symbol Palms, with barcode scanners, and we actually had the only Symbol Palm Instructor (who also happens to be a family friend ) come in and we got out of half a day of school, and learned some cool stuff about prgramming a Palm. Although, he showed it to us in Code Warrior, which complies both C and C++ code. He actually showed us the difference in size, it was a pretty big difference, so make sure you get rid of everything else on the Palm. Don't forget spare batteris either!
Unread 02-02-2002, 19:52
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
C++ need not be huge...
If you read a bit about using C++ in the embedded systems area, you will see that there are a few relatively simple rules to getting C++ to compile essentially as compact as C.
I am not yet an advocate but I am open minded.
C++ has many advantages I don't need. It does have a few things that might be worth the bother if I can get them cheap/free. The trick is to get the stuff I want without paying somewhere else because I didn't know what I was asking for.
The more we understand about our tools the more useful they become.
Joe J.
gearing design calculation question caffel Motors 4 24-03-2003 17:34
Dashboard Decoder Release Version 1.0 Now Available! archiver 2000 1 23-06-2002 22:50
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
Dashboard Viewer Khalicl13 Technical Discussion 8 15-06-2001 23:36
