OCCRA
Go to Post Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience. - AustinSchuh [more]
CD-Media
Unread 09-15-2018, 01:29 PM
risho900 risho900 is offline
FRC #6897 (Astraea Robotics)
Rookie Year: 2015
risho900 is a name known to allrisho900 is a name known to allrisho900 is a name known to allrisho900 is a name known to allrisho900 is a name known to allrisho900 is a name known to all
Re: Pneumatic System Help
Originally Posted by Mark McLeod View Post
Then the whole CAN-bus is inoperable.
I'd still suggest testing a single component on the bus at a time with the roboRIO to isolate the issue.
Rewire each connection with new wire-redoing each of the connectors carefully, in case it's a wire whisker type short.
Just use a new set of wires temporarily:
First, directly wire CAN from the roboRIO to the PDP and just see if the PDP then shows up on the configuration page.
Second, just wire the PCM-no PDP (don't bother with a 120ohm terminator for this test), just direct connect it alone to the roboRIO and see if it shows up on the configuration page.
And if this doesn't work, do I have to send out something for repairs?
Unread 09-15-2018, 04:05 PM
Tom Line's Avatar
Tom Line Tom Line is offline
Don't lay blame. Fix probems.
FRC #1718 (The Fighting Pi)
Do you have another pcm you can try?
Rookie Year: 2015
No I don't.
Unread 09-15-2018, 06:06 PM
Rookie Year: 2015
Also, in case I do have to send it in for repairs, anyone know how much $$ and how long it would take CTRE to repair it?
Unread 09-15-2018, 07:54 PM
You need to discover from your tests just which of the components might need work, or if it's just a wiring short.
The various suppliers are usually very helpful in getting their products fixed.
Close by teams might also be able to help with the loan of components once you identify just which one is the trouble.
Will you be attending any off-season events, e.g., Brunswick Eruption, where help is also available?
We are what we repeatedly do. Excellence, then, is not an act, but a habit. -Aristotle
Unread 09-15-2018, 08:38 PM
Rookie Year: 2015
Going to Ramp Riot. Would prefer to fix it before it though.
Unread 09-15-2018, 10:45 PM
keco185's Avatar
keco185 keco185 is offline
FRC #0484 (Roboforce)
keco185 is an unknown quantity at this point
Try uninstalling and reinstalling the Pheonix Lifeboat config on the roboRIO
Unread 09-15-2018, 11:18 PM
philso philso is online now
FRC #3103 (Iron Plaid)
A couple of years ago, CRTE gave me a price of around $20 for replacing the Weidmuller connectors on a VRM. If you have a dead CAN chip, I would expect a similar price. I did not end up sending it in so I don't know how long it would take them to turn around a repair.
It would be best if YOU PHONE CTRE to find out how much the will charge for the particular repair you need and how long it will take them. They are pretty easy to talk to and very helpful.
Have you tried swapping in a new RoboRio? If it turns out your RoboRio has a bad CAN chip, you should phone National Instruments to find out how much they would charge and how long it would take them to fix it for your.
Unread 09-16-2018, 09:47 AM
Rookie Year: 2015
Don't currently have any spare electronics to swap in or out. How can we tell if it is the roborio thats the issue without having to swap it out?
Unread 09-16-2018, 01:21 PM
Can you get in touch with a team near you and borrow one? Swapping in a know working RoboRio is the simplest and fastest way of determining if it is the CAN transciever chips in your RoboRio that are the problem. That would be the first step I take with the boards I design at work.
If forced to troubleshoot a situation like this where I have only one sample of the board available, I would be using an oscilloscope to monitor the CAN lines to make sure the output waveforms went to the appropriate voltages at the appropriate times.
Has your team ever had the PCM working?
Unread 09-19-2018, 03:22 PM
Rookie Year: 2015
No we have never had a PCM working and I might be able to get a RoboRio from another team.
Unread 09-19-2018, 09:33 PM
This might be a good time to find a team near you that is successfully using the CAN bus and meet with them. Preferably, find one using the same programming language that you are using. Bring your robot and programming laptops when you visit them. If you have never been able to get a PCM to work, you may have some sort of software issue. They may see something that you don't know is wrong.
Unread 09-19-2018, 09:45 PM
Chief Robot Inspector
After looking through the thread, this thought jumps to mind. Please check that all the CAN bus wiring has been stripped. I have a number of teams each year that have the CAN wires installed but they were never stripped or at least not stripped to the correct length. Try a pair of wires between the PDP and the RoboRio only and see if you can address the PDP as suggested above.
Knowledge is power. Power UP!
Unread 09-20-2018, 10:33 AM
Yes! The Users Manual for the PDP and PCM gives the strip length needed to make a proper connection. These manuals can be found on the CTRE web page for each of these products.
Unread 09-21-2018, 07:44 PM
Rookie Year: 2015
I tried all these suggestions and nothing worked. Roborio power light is still red and when I connected Roborio to PDP with CAN, the CAN lights on PDP were still blinking orange. Nothing appeared on roborio web dashboard either.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
