OCCRA
Go to Post Each match is a learning experiance - the only thing you can do is get better. - SuperJake [more]
CD-Media
Unread 09-23-2018, 11:00 PM
CupOfCocoa's Avatar
CupOfCocoa CupOfCocoa is offline
AKA: Luke VanHouten
FRC #5803 (Apex Robotics)
Team Role: Scout
Rookie Year: 2016
CupOfCocoa will become famous soon enough
pic: 5803 4513 Double-Climb West Valley
Unread 09-23-2018, 11:01 PM
Marcus Q Marcus Q is offline
Reversible bumpers are my trigger
AKA: Marcus Quintilian
FRC #5406 (Celt-X)
Marcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond reputeMarcus Q has a reputation beyond repute
Re: pic: 5803 4513 Double-Climb West Valley
What's up with the chain path on 4513's bot? I'm trying to figure it out but it's stumping me.
2012-2015: 865 Warp7 Team Captain
2016/17: Free Agent Mentor
2018-present: 5406 Celt-X
Unread 09-24-2018, 08:39 AM
FrisbeeFunTime's Avatar
FrisbeeFunTime FrisbeeFunTime is offline
AKA: Erik Yngstrom
FRC #1768
Rookie Year: 2015
FrisbeeFunTime is a splendid one to beholdFrisbeeFunTime is a splendid one to beholdFrisbeeFunTime is a splendid one to beholdFrisbeeFunTime is a splendid one to beholdFrisbeeFunTime is a splendid one to beholdFrisbeeFunTime is a splendid one to beholdFrisbeeFunTime is a splendid one to beholdFrisbeeFunTime is a splendid one to behold
It almost looks as if the small one is for actuating the arm and the big one is just some type of hard limit for the rotation of the arm.
Unread 09-24-2018, 12:46 PM
carpedav000's Avatar
carpedav000 carpedav000 is online now
FF: TSIMFD
AKA: David Carpenter
no team (Lincoln Tech)
carpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond repute
Thatís a cable protector...
It isn't shiny enough.
Unread 09-24-2018, 12:53 PM
AKA: Erik Yngstrom
FRC #1768
Rookie Year: 2015
That's not a a able protector. It's bolted through on the top like it's chain and it's also wrapped around a sprocket at the bottom of it's run. Also looks exactly like the chain used in the run right next to it.
Unread 09-24-2018, 01:03 PM
MikLast's Avatar
MikLast MikLast is offline
Waiting for my Tableau Sponsorship
AKA: Mikal Dieatrick
no team (Volunteer)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
4513's cable protectors are at the back. In the front is a fair bit of chain.
Join the FRC Discord!
FRC4513 (Circuit Breakers)
*Student: 2014-2017
*Drive Coach: 2016-2017
Volunteer
A/V: West Valley, PNW DCMP 2018
Unread 09-24-2018, 05:33 PM
Tom Line's Avatar
Tom Line Tom Line is offline
Don't lay blame. Fix probems.
FRC #1718 (The Fighting Pi)
It appears that the long chain is fastened at the top of the lift and the bottom. A sprocket is engaged in the middle of the chain. When that sprocket turns, it lifts and lowers the arm by moving the arm up and down the chain.
Unread 09-24-2018, 05:36 PM
FRC #5406 (Celt-X)
But why?
Unread 09-24-2018, 05:56 PM
Mike Marandola's Avatar
Mike Marandola Mike Marandola is online now
Trust the Process
AKA: Mike Marandola
FRC #0316 (LUNATECS)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Looking at this picture, it seems like the PG71 is powering the sprocket that 'climbs' in the loop of chain, making the four bar and intake go up. I'm guessing the two close sprockets are to get a better chain wrap. Really strange but they seemed to do pretty well.
LUNATECS.org
FRC 316 Student 2007 - 2011
FRC 316 Mentor 2012 - 2017
FRC 316 Lead Technical Mentor 2018 - ?
Unread 09-24-2018, 06:01 PM
MikLast's Avatar
no team (Volunteer)
Originally Posted by Mike Marandola View Post
making the four bar...
im fairly sure that the lift is not a four bar, at least not like 1778/33's. https://youtu.be/EmvDj4SMwQ0
*Student: 2014-2017
Volunteer
Nathanarcher500 Nathanarcher500 is offline
FRC #4513
Nathanarcher500 is an unknown quantity at this point
I am from team 4513 and yes the chain is used for raising and lowering the arm. We used 2 sprockets, one fixed and one able to move so that as the arm extends in a half circle motion it keeps tension so the chain doesn't slip
Unread 09-24-2018, 06:05 PM
Trust the Process
AKA: Mike Marandola
Yes it is, there are two next to each other. 1778 and 33 both have a double reverse four bar.
LUNATECS.org
Unread 09-24-2018, 06:11 PM
FRC #4513
We have 2 stages to our lifting mechanism, the first stage is a 4 bar system and the other section is a elevator that moves straight up and down
MikLast's Avatar
no team (Volunteer)
Maybe im just not used to seeing them on an elevator also...
Theres a reason i didn't help build haha
*Student: 2014-2017
Volunteer
Unread 09-24-2018, 07:42 PM
FRC #5406 (Celt-X)
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
