Go to Post I didn't say it bad English, though. Grammatically, it's perfectly proper. - Greg Ross [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 09-07-2003, 02:38
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
Ion Lifters
In the latest issue of Wired magazine, there was an article about 'Lifters.' These are simple little devices that use really fun physics or magic to produce lift (and by doing so, hover) with no moving parts. Directions for making lifters can be found here. These are very simple devices, as their lift comes entirely from the ions that are created and flow between the positively charged wire and negatively charged foil part below the wire. In order to create enough force to counter that of gravity, though, the charge between these two must be very high and thus these lifters require a power supply of around 20,000 volts (ouch). Twenty-thousand volts isn't too bad as long as the amperage is still very low (it shouldn't be any worse than a touch of static electricity) but it is still enough to fry small transformers when they're connected to a house's current backwards so as to increase the voltage rather than decrease it (twice did my room partake of the magic smoke last night.)
I've made a couple of these little lifters, but I haven't been able to supply the voltage they need to start ionizing air. Does anyone have ideas as to what I could do to get that kind of voltage in my house using mainly spoons (or other things I might have lying around or be able to buy inexpensively)?
[Or if you manage to build one of these yourself, I would love to hear about it]
Video
Unread 09-07-2003, 03:08
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
According to Arthur C. Clarke's Third Law, "any sufficiently advanced technology is indistinguishable from magic." This definitely constitues a "sufficiently advanced technology", in my opinion.
Very awesome stuff they're doing, these days.
In my high school physics class, my teacher (coach of 258, at the time, and currently coach of 360), Eric Stokely, had this fixation on flying cars. It was quite funny to hear him complain about the fact that they don't exist, yet. Oh well, one step closer.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 09-07-2003, 03:31
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
I've been toying with the idea of building one myself for a while, but I'm afraid it would probabaly turn into one of those projects I'd forget about.
Unfortunately, there isn't much that you can find around your house for such a project, other than some flyback transformers from an unused/old television. Be careful poking around in there, though. The other (cheap 'n' dirty) option that has been discussed around various "lifter" (I like to call it electrokinetic propulsion, it's more professional) sites, is using the ignition coil from various automobiles.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 09-07-2003, 07:21
Electrical Engineer
Rookie Year: 1995
As stated on the web site, the HV power supply from an older style computer monitor or TV set should be all the power supply you need.
One thing that jumped out at me... Use a high voltage wire for this job. As an example: P/N 39X2220 from: http://www.dearborn-cdt.com/catalog/HW-39X.html is good to 20KV. Please don't shortcut here...
Another thing, wear safety glasses!
I think that this is a great project but I strongly recommend that you get a EE or physics teacher to supervise. Working with high voltage is not something you should cavalierly attempt.
Mike Betts
As easy as 355/113...
Unread 09-07-2003, 07:25
Electrical Engineer
Rookie Year: 1995
Mr. Plasma,
Send Mr Stokely this link: http://www.moller.com/skycar/
Mike Betts
Unread 09-07-2003, 09:52
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
I believe this probe used ion technology:
http://nmp.jpl.nasa.gov/ds1/
And here are some more directions on how to make an ion producing device:
http://www.nutsvolts.com/PDF_Files/ionmotor.pdf
Its a pretty cool form of propulsion if you ask me. Reliable, cheap, and ,compared to a rocket, it lasts longer.
I remeber watching a movie in physics. The guy was talking about ion propulsion and how it was first mentioned on star trek.
Unread 01-03-2007, 10:47
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Re: Ion Lifters
I actually MADE one of these!!! But they are not ion powered... Its just unknown what they are powered buy.. that is, according to nasa.... And they own the patant... $@#$@#$@#$@# thiefs.
Unread 01-03-2007, 11:02
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Re: Ion Lifters
I watched them make one of those on MythBusters last night and it worked.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Build a Ion Ray Gun MattK Chit-Chat 12 20-09-2003 14:07
