Go to Post Don't be in a rush to build a robot until you know what robot it is you need to build. - Chris Fultz [more]
Unread 09-07-2003, 10:31
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
3rd Joystick- Counselor
Hey guys, I am a counselor at the FIRST EDU camp. One of the teams wants to use a 3rd Joystick.
Does anyone have code that I can borrow.
Thanks!
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 09-07-2003, 11:39
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
What do you want it to do?
What do you want the 3rd joystick to do? It is easy enough to write some code for you but I don't know what you want done.
Joe J.
Unread 09-07-2003, 12:40
MattK's Avatar
Tap it.
it is to controle a robotic arm
my myspace!
Unread 09-07-2003, 13:08
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Matt... I think your going to need a little bit more information.
Lots of the mentors on these forums (including Joe) would be willing to help, if you could just clarify what exactly you need.
You can't expect to come in here say "I need help building a robot" and have someone send you plans for exactly what you need.
Good Luck,
John
PS - I'm not a software guy, and couldn't help you out if I tried.
Unread 09-07-2003, 13:11
MattK's Avatar
Tap it.
Alright here is how it works... or is suppose to
We have a basic 4 wheel cart.... each wheel is independent.
We are using 2 joysticks (1 for each side)
On the cart we have a arm, we want it to be controlled by a 3rd joystick so we can vary the speed at which the arm moves.
Is it possible to plug a joystick into 2 or 4 to make it work?
Thanks,
Matt
my myspace!
Unread 09-07-2003, 14:25
AKA: Dr. Joe
FRC #0088 (TJ2)
What INS to What OUTS
Give me a simple table:
For example
p2_y => PWM2
p2_x => PWM4
Joe J.
Unread 09-07-2003, 15:23
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
I always laugh when I see people ask for software help because the way it's done is analogous to me asking for someone to "design me an arm for my robot."
We need details. What does each axis of the stick do? And more specifically as Joe said, what output should each input map to?
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
