Go to Post Success is making a difference. - SlamminSammy [more]
Unread 08-07-2003, 22:28
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
Dashboard?
I was looking at the dashboard program from innovation first and I noticed that it only shows 2 pwms: PWM1 forward/reverse and PWM2 forward/reverse.
I'm not the teams programmer but I'm wondering if anyone has ever made their own dashboard program similar to innovation first's but it would show at least 8 pwm's. How would I go about making a new dashboard?
Unread 08-07-2003, 23:13
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
what do you mean by program? like something that sits on your laptop and gives you feed back?
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 08-07-2003, 23:15
yes, that's what i mean
Unread 08-07-2003, 23:20
Just Browsing
AKA: ryan albright
I downloaded one off the white papers, it was made by team 7, i haave been messing with it. Its pretty good i forgot where i found it look around white papers to find it
Mentor 1083 2005
Unread 09-07-2003, 00:22
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
The fact that it only displays PWMs 1 and 2 is because that's all the data that gets sent to the dashboard port. For full details, you can grab InnovationFirst's documentation from their website.
Also, I've written a linux dashboard viewer (gDash) which you can get from my website www.robbayer.com, though it suffers from the same lack of PWM feedback for the reason stated above.
--Rob
Unread 10-07-2003, 09:33
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
I'm assuming you're speaking of the one made by me while I was on team 7 (I believe it was written in 2000). It can be found here: http://www.bontragers.net/first/
Matt
Unread 10-07-2003, 16:05
Just Browsing
AKA: ryan albright
Ya thats the one . I liked it It helps us debug alot of things
Mentor 1083 2005
Unread 10-07-2003, 20:41
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Re: Dashboard?
i've had plenty of trouble with this problem, trying to send back all the PWM data. I've learned that by manipulating the Out bits (Out8 --> Out15) you can send up to an entire byte back. That's enough to show two states for each PWM, but only two. I have tried to multiplex the feedback, by timing based on the Out7 bit (the one that toggles on and off to show that the PBASIC chip is working), but I have had no luck with that, as the C++ code could not decode the streams correctly (sometimes data would come back right, other times wrong, but predictably wrong). In short, I gave up on that and figured out how to deal with less variables being given back.
I'm hoping that next year the new controller will have much more flexibility with what is sent back, and how much is sent back. This is almost a must, if we are to have more autonomy. I think that it's useful to feedback anything and everything you can, so you know if anything is wrong at the end of autonomy, but that's currently next to impossible without building a custom board. In anycase, we should be learning of the new controllers soon, so don't pull your hair out if you can't get a dashboard that does everything you want it to do with these controllers.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 10-07-2003, 21:45
piotrm's Avatar
piotrm piotrm is offline
AKA: Piotr Mardziel
FRC #0190 (Gompei and the HERD)
piotrm has a spectacular aura aboutpiotrm has a spectacular aura about
Send a message via AIM to piotrm
hm
i'm not sure what the first dashboard program is, but i was developing sort of a dash board program for my team which was to be displayed on a laptop screen on the driver station
it was done in flash and i basically had the flash side done but since the major reason why it was being made (our CVT's) was never made a componenet of the robot, there wasnt really much use of this dashboard display
i may do some work on it more for next year's robot if there is use of it (CVT or complicated robot features). it also was supposed to show a map of the field with the robot in it using the data from our INS system which i dont think really was accurate enough in the long term anyway
all the data was to be sent using the few pins available that are sent back to the driver station, all the data was to be encoded but this part wasnt even started so i dont know how it would have went and i read here that people had some problems with this and indeed lets hope for better first hardware next year (would make things easier)
i have one picture of a really early version being developed at http://users.wpi.edu/~piotrm/project...irst_hud_1.jpg
since its in flash it doesnt have direct access to hardware like the serial port so the intention was to write a tcp server to be run on that computer which would communicate with the hardware and serve the data via tcp (flash XML Socket routines). i have had much flash/tcp communication experience already (tacOps display server) so thats not the problem and can help anyone out if they are interested in doing something like this
good luck
Unread 11-07-2003, 00:49
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
rob bayer
i think robs programs will do what you want, if im nto mistaken (which i may be) there is a program out there or here in the whitepapers that give you feedback for all the PWM's...
~Mike
-Michael Dessingue
Unread 11-07-2003, 09:18
Maybe I'll get around to updating it a bit someday. When I have some free time (ha!). I'm always amazed by the number of people who found it useful at some point in time.
Matt
Unread 11-07-2003, 13:01
Re: rob bayer
~Mike
Sorry, but it won't. Unless you want to use the LED feedback bits like Ian W. suggessted, you're not going to be able to see the actual values of any of the PWMs.
Unread 11-07-2003, 14:19
OK then thanks Rob, i guess i was mistaken and that the program i was thinking of doesn't give you analog feedback, only binary.
~Mike
-Michael Dessingue
Unread 11-07-2003, 17:55
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
firestorm dosent work. WHY?
Unread 11-07-2003, 19:17
College? What?
there is one way to give feedback of all 16 PWMs, and all it requires is a pot and some coding knowledge.
i just thought of this now, so i think it should work, someone may want to check this though. second, probably a bad idea for use during a competition, due to extra code.
first of all, plug your joystick in, as we have the wheel that we can use as a pot (yay!).
Divide 255 by 16, we get approximately 16, but since it's PBASIC, let's truncate and make it 15.
Down at the very bottom of your code, after everything but the SEROUT (this way you're sure to be outputting the correct values), but something like this (excuse any syntax errors, it's been a few months )...
switch (wheel_var)
case 0 to 15:
out8 = pwm1.bit0
out9 = pwm1.bit1
out10 = pwm1.bit2
out11 = pwm1.bit3
out12 = pwm1.bit4
out13 = pwm1.bit5
out14 = pwm1.bit6
out15 = pwm1.bit7
case 16 to 30:
out8 = pwm2.bit0
out9 = pwm2.bit1
out10 = pwm2.bit2
out11 = pwm2.bit3
out12 = pwm2.bit4
out13 = pwm2.bit5
out14 = pwm2.bit6
out15 = pwm2.bit7
and so on till you get up to pwm 16.
turn the wheel, you can probably estimate the distance needed pretty easily, otherwise you can very easily output it to a laptop computer and see what pwm you're getting (i believe the wheel on port 2 is sent back already).
now, if you have the 2003 controller, put it into User Mode, and you get the pwm values right there on the controller, nothing else needed.
if you don't have the 2003 controller, i'm sure there is a program, or i'm willing to write a quick and dirty command promt program that will simply output the pwm value (converted back into decimal or 0 - 255).
as I said, this is not the best code to have in a competition ready robot, but as long as you're just testing, i guess it's fine.
DISCLAIMER: I think this should all work, but I haven't tested it (because I'm too lazy to boot into Windows, find my old robot code, add this in, and plug it into the controller sitting on my desk). If you have any problems (like robots blowing up or killing people) either you did something wrong, or it's a hardware problem .
<EDIT> Sorry about the lack of spacing, but I can't think of any other way to make it space correctly</EDIT>
AIM --> Woloi
Custom dashboard program available. Interest? archiver 2001 4 24-06-2002 00:45
Dashboard Decoder Release Version 1.0 Now Available! archiver 2000 1 23-06-2002 22:50
Dashboard Protocol Library archiver 2000 9 23-06-2002 22:24
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Dashboard Viewer Khalicl13 Technical Discussion 8 15-06-2001 23:36
