Go to Post Pro-tip: Friends don't let friends play defense! (in qualifications) - Mr. Lim [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 11-07-2003, 22:27
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
YaBB comes to mind, but there are a lot of less extensive ones out there; all you have to do is search. I'm not sure if Phorum must have SQL either. The Woburn Robotics Forums are hand-coded for an example of a simple Perl one, so you could explore that idea if you have the means.
message board archiver 2001 1 24-06-2002 04:07
message boards, chat rooms, etc archiver 2001 9 24-06-2002 03:55
