Go to Post Where before there was boredom and lack of understanding, suddenly I saw why competitions would be fun. Not to sound corny or anything, but it brought a side out of me that I used to never show people in public. I danced, cheered, screamed, and had a blast. - DevilChild [more]
Unread 26-06-2003, 07:22
We have several...
Over the years we have used servos to activate a microswitch on the robot for a program branch jump, to drop an anchor to hold us on a ramp, release a magic tongue and this year we used servos to brake the drive mechanism for our wings (that is what holds them up at the end of the match!) Sometimes you don't need a lot of power, just the will to move.
Unread 26-06-2003, 22:06
Sully Sully is offline
no team (The Bobcats)
Rookie Year: 1994
Sully is on a distinguished road
Send a message via Yahoo to Sully
At one of the regionals in 2003 I noticed one team (I don't recall the no.) that was using a servos to interface with the Victor 884. The servo was used to activate a switch that was wired to the brake / coaster jumper on the Victor. This enabled the team to actively change the drive system from a dynamic brake system to a coast system. I am not sure what their reasoning was but it was a very clever way to overcome a problem. Simply put the servos can be used to activate switches of all types to suit the needs of the robots.
Unread 26-06-2003, 23:28
James114's Avatar
James114 James114 is offline
FRC #0114 (Los Altos High School)
James114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really nice
Send a message via AIM to James114
Cool
In 2001 my team used a servo to wave a small American flag back in forth
Unread 14-07-2003, 23:56
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
My team has never used the servos, but we will next year...
Anyway, you can use it to shift gears as many say, or do useless stuff, but I saw one team that put two servos on their lamp and raised or lowered it every time they had to go under the bar. The only problem was it took too long to move one time, and they broke their lamp. You can buy servos withing a huge range of power, from about 5 oz/in of torque to about 1000 oz/in.
Unread 15-07-2003, 00:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You can buy wheelchair motors with a huge range of power that doesn't mean you can use them. Servos not provided in the kit are illegal since they have a motor inside. Sorry.
Unread 15-07-2003, 00:34
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
Rookie power
This is really a neat and compact design. We used the plastic drill motor mounts and mounted them to our steel frame. We then added a little L shape piece of aluminum on all four sides to serve two purposes:
1) Mount four small muffin fans to cool our motors down
and
2) Support the servo mounts
The airflow was superb, we didn't overheat once after they were installed, and being able to switch from high to low gear allowed us to have a quick/precise autonomous mode followed by a powerful low gear. It all worked out nicely =)
I would also like to point out that it was one of our wonderful students who designed that little gear-shift mechanism. Hope the picture helps
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
Unread 15-07-2003, 00:52
#1011 (CRUSH)
Oh, one more use I forgot about! Some of you may remember Gila III from 2000 (Team 64). We used a servo to release the gate that let out all of the balls in our basket into the trough.
The RED arrow is where the servo is mounted (I know its not very visible) and the BLUE arrow is what it was actually moving. There is another BLUE arrow thing on the opposite side, and it works almost exactly as the gear shifting mechanism in my post above. BTW, that is Mike Rush in the picture... my personal hero, and the man responsible for me being so involved with FIRST
Unread 16-07-2003, 21:43
Originally posted by WakeZero
Rookie power
Quite impressive transmission. Even more so for a rookie team. But on the subject of motor cooling, we never did it. You think it would help, but not really. Blowing air on the motor doesn't do much. The motor doen't have enough surface area. Even if you make a custom heat sink and use silicon thermal gel, you still won't do much. You'll cool the outside of the motor, so you'll cool the magnets. You don't really cool the wire windings, and that's what you want to cool. Even if you manage to cool the wires, you won't lower the temperature too much, so you won't really improve the conductance enough to ever notice. Cooling works, but not with fans. For example, team 254 injected liquid oxygen (or something like that, i forgot exactly) from a can into their motors right before competing. This cooled the wires to about 250 kelvin (-23 C) or so they say, and I think that is close. This gives their robot a hugh advantage during autonomous mode, since they can really shoot up the ramp. But after a minute the motors heat up again.
Unread 16-07-2003, 22:34
We used a heat sink and heat sink grease on each of our drill motors. This lowered the temp on the surface of the can nearly by half. They worked really great and we never had any overheating problems. Here's where you can buy them and a pic. You should also be able to find them at any quality hobby reatailer such as Hobby Town USA.
As for the colling spray, it is canned air that you buy from Office Depot or Staples or Fry's. When the can is turned upside down, the compressed gas comes out as an ice cold liquid spray. This works very well for cooling the CAN of the motor between matches. It is also very useful for cooling breakers before matches to ensure that they don't trip as much.
The reason I'm telling you all this is from something Andy Baker said that I agree with:
There are so many advantages to giving these designs out. We as a team
feel that giving these designs to other teams “raises the bar” of FIRST robot designs and all of
FIRST benefits.
Last, I would strongly advice against cooling any part of the motor except for the can. You can accidentally freeze the thin insulation off the armature windings or even more easily crack a brush. If you absolutely must spray the inside or endbell at all, do it on a room temperature motor.
PS. Sometime hopefully before the end of the summer I will have a little white paper made of "Tips, Tricks, and Field Side Fixes" that will cover the things above and much more.
Unread 16-07-2003, 22:41
Yes, note the word "surface". It's inside that you want to cool. Anyway, we never use cooling and we never have problems. I frequently touch the motors to check their temperature. I do it right before we lift it out of the field, and they're never very hot.
Unread 16-07-2003, 22:44
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
True, but the surface temperature is usually an indicator of the internal temperature. If it's hot, the inside surely is, and if it's not, the inside is probably cool (relatively speaking).
Jeff Waegelin
Unread 16-07-2003, 22:50
My post above got posted without being complete , it's all edited and finished up now.
Unread 17-07-2003, 12:00
#1011 (CRUSH)
First, thanks for the compliment =)
As for the cooling fans, I forgot to mention that they are all pointing in the same direction. So you have:
Fan --> Motor --> Fan
The arrows represent the airflow, and the left fan brought in the cool air while the right fan sucked out the hot air. I can see your point about just blowing cool air onto the casing, but we actually took the hot air out
It may not have made a huge difference, but we did notice that after we installed them we never overheated like we did a couple times before
Unread 17-07-2003, 14:46
Wow, our motors never came close to overheating. Maybe it's because you guys used the drills and we used drills+chippies. Looks like they help each other out enough so that they don't overheat. Cool!
Unread 17-07-2003, 15:40
And let's not forget about gearing and wheel size. Those both play an important part in current draw and heating.
pic: creative shirt CD47-Bot Extra Discussion 3 17-03-2003 23:08
FIRST and Creative Mediums archiver 2001 1 24-06-2002 04:11
Hi Colleen archiver 2000 2 23-06-2002 22:03
weight advice SharkBite Technical Discussion 36 15-02-2002 07:30
User Titles Brandon Martus CD Forum Support 27 04-06-2001 22:23
