Go to Post I think that if you're using semantics to pass inspection you're trying hard to be lazy (Trust me I'm really good at doing it). - Thayer McCollum [more]
View Poll Results: Are you using Reactor
yes we are using Reactor 6 35.29%
no we are not using Reactor 11 64.71%
Voters: 17. You may not vote on this poll
Unread 02-02-2002, 22:31
Funkymunkey90's Avatar
Funkymunkey90 Funkymunkey90 is offline
Funkymunkey90 is an unknown quantity at this point
Post Reactor poll
Hey all, I want know how many people are using Reactor. If you don’t know what it is used for, then read the manual and find out a more in-depth explanation. Reactor is physics plug-in, just like simcloth but better in my opinion. I’ve been using this plug-in for about a year almost, ever since the TSA SciViz nationals in Richmond VA. It’s a hard plug-in to use and under stand but makes animating collisions and gravity a lot easier.
Team 384
Animation Team Capitan
Unread 02-02-2002, 23:07
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
I don't think I've got a single particle system or dynamics situation planned in the whole thing, so no. CS, on the other hand... God save CS when it works right. Even though it leaves a lot to be desired when trying to adjust the center of gravity.
Man is the ape that laughs.
Unread 03-02-2002, 03:33
BrainCore BrainCore is offline
#0604 (Silo Whats)
BrainCore is an unknown quantity at this point
Send a message via ICQ to BrainCore Send a message via AIM to BrainCore
Reactor is extremely easy to use. The problem is that it is so limited. You can learn how to use all the tools effectively in under 30 minutes. Well, most at least.
I don't see much use for it in my animation unless I wanted to lift a clothe off our robot or field, but that'll probably be a cliche since everyone has Reactor.
Another problem with Reactor is that the collision system isn't that great. Unlike Simclothe, different dynamic objects will never get even close to each other, so I can't even use it for clothing.
Anyone find any other uses for it?
-From the Core of the Brain
Unread 03-02-2002, 23:00
Ydnar's Avatar
Ydnar Ydnar is offline
#0932 (Circuit Chargers)
Ydnar is an unknown quantity at this point
Send a message via AIM to Ydnar
only other reason i can see y one would use reactor is realistic hair movement on ppl, but i don't think anyone has the time to go through that much trouble, esspecially when you can use shag: hair if you need hair, or many other plug-ins for hair...
i know we are not using reactor.....
-Come and go, and rise and fall with glory, maybe one day i'll be famous too
Unread 20-02-2002, 23:10
Sunny Thaper Sunny Thaper is offline
None #0064 (The Gila Monsters)
Team Role: Animator
Sunny Thaper is an unknown quantity at this point
Send a message via AIM to Sunny Thaper
Cool
Yes, we are definately using reactor and loving it. It is very simple to use but to get what you want is time-consuming. BrainCore - You might have the problem of bumping your tolerance up too high. If your objects react to each other before they actually touch each other than it is definately tolerance. Reactor can be used for a huge amount of things from clothes to water to even terrain modeling.
