Go to Post So, in the good old FIRST spirit, let's all start brainstorming and sharing ideas, ok? :D - LauraN [more]
Unread 31-01-2002, 17:43
Ben Mitchell Ben Mitchell is offline
Ben Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond repute
tripping breakers/burning motors
How easy is it (with chiaphua or drill motors) to trip those 30 amp/ 60 amp breakers??
Are any team have major problems constantly tripping breakers?
What about ampage "spikes" when a robot is shoved/rammed??
Are they a problem??
Are there any ways to lessen this problems via programming or design? (besides lessening tension on drive system(of course))
Also,
Are motors heating up a major issue this year (we have'nt tested ours yet)
Do those chiaphua motors heat up? I suspect they would, as well as trip breakers.
Are heat sinks for motors legal to keep the heat down? Would they be a better option than a fan of some sort?
Thanks for any info, this board has been a great help this year.
--Ben Mitchell
Is
Unread 31-01-2002, 19:40
WernerNYK WernerNYK is offline
AKA: Chris Werner
FRC #0190 (Gompei & the HERD)
WernerNYK is a jewel in the roughWernerNYK is a jewel in the roughWernerNYK is a jewel in the rough
Send a message via AIM to WernerNYK
We're having this problem
Yes, we are having this problem... We are a rookie team that is having problems developing our drive train.
We are using the two drill motors for 4 wheel drive to create a 3:1 ration along with our custom-fabricated tensioners. We at first had 2 wheels bolted together with the sprocket in between and we were tripping breakers whenever we tried to turn on the carpet (We have no problems on smooth surfaces).
Today, we went down to 1 wheel at each position and made new spacers for the axels. It seemed to work a little better, but we are still tripping breakers in a way that is not acceptable (Every few seconds doing 360s).
Does anyone have any experience or ideas on how to resolve this problem?? We also made custom motor mounts....we made sure that they are not "pinching" the motors, but could this be causing this problem?? We are running out of reasons why this may be happening.....
Unread 31-01-2002, 19:51
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
I assume you are using the drill transmissions. Are they in high or low?
It sounds like you are stalling the drill motors because you don't have them geared down enough.
Unread 31-01-2002, 19:57
AKA: Chris Werner
Yes, they are locked in high.... From your previous reply, is this a good or bad thing??
Unread 31-01-2002, 20:10
#0894 (Chargers)
How big are the wheels you're using? The drill motor in high geared down 3:1 is going to theoretically make the wheel spin at 330 rpm. A 6" diameter wheel spinning this fast should (theoretically) make the robot move at about 9 ft/s. You need to gear it down more. The problem is that you have it geared so high (and spinning so fast) that you're not getting enough torque. You are stalling the drill motors, upping their current draw to around 114 amps (per motor). This is why you're tripping the breakers so fast (they provide 200 amps for a number of seconds). Gear them down more and you should be alright.
Unread 31-01-2002, 20:13
AKA: Chris Werner
Hmmm, ok....that makes sense, but it doesnt seem like we are moving that fast. We are using 8" wheels, with the 3:1 gear ratio. We also have gears that are already machined for a 4:1 ratio....
Unread 31-01-2002, 20:14
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Last year we used the drill motors, with transmission, on our robot and NEVER blew a breaker.
We had a 24 tooth on the drill motor and a 60 tooth on the 8" wheelchair wheels.
We also had the ability to shift gears.
Last year we were able to pull a fully loaded stretcher up and over the teeter tooter with no problem.
One of our secrets was the design of the motor mount. We made them out of aluminum. They were very crude but they were a great heat sink so our motors never got hot. The drill motors were fully enclosed.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 31-01-2002, 20:18
#0894 (Chargers)
If the drill motors are blowing breakers, it's either because you have too much of a side load on them or, more likely, because you have them geared too high.
Unread 01-02-2002, 09:35
The reason your robot is not moving very fast is because the motor is running near stall (due to the load you are giving it)and therefore at a very high average current draw. Since the 30 amp circuit breakers are "thermal" devices, they will trip with high average currents and then will continue to trip more often after the first time due to the high internal heating. A quick fix would be to slow down the drive in software but the gear ratio change is what you really want to do. Even with a good gear selection some motors will heat up. Take the Fisher Price for example, it has a really inefficient fan inside to circulate air. Block the holes with a mounting bracket and you are just complicating the problem. To add to all that, the fan is just "friction fit" on the shaft inside the motor and when the motor temp reaches the melting point of plastic, the fan stops.
Although there is no track record on the "Chalupa"
motor, I am going to guess it will have a serious heat issue. It is designed for intermittant duty in an all weather environment so there is no air movement through the motor. The best method on this motor is heatsink in the mounting design.
Please make sure (with accurate measuring on a regulation playing surface) that your motors are not running near stall speeds and adjust gearing if they are. This will insure long life on motors and NO tripped circuit breakers.
Good luck all,
Unread 02-02-2002, 07:55
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
in reference to WernerNYK's post:
I'm the team leader for his team (Team 871). I just wanted to drop a note saying we took the advice posted and dropped into LOW GEAR, the robot moves slower but we are very happy with the results. It has no problem pushing an adult. :-)
Thanks for the help!
Unread 02-02-2002, 21:44
kacz100 kacz100 is offline
Battle Cattle!
#1466 (Webb Robotics)
kacz100 is on a distinguished road
Send a message via AIM to kacz100 Send a message via Yahoo to kacz100
Does anyone know what the highest gear ratio that would work for the drill motors in 4 wheel drive? I am just curious becasue I wanted to do this but my team decided otherwise.
Kacz
Team #40 Alumni 1999 - 2002
Team #885 College Student/Mentor 2003
Team #1466 College Student/Mentor 2004
Unread 02-02-2002, 22:00
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
In '98, the last year we ran without gear change, we ran 4 wheel drive with about 1:5 ratio in high gear driving the 6 inch wheels. We had Skyway wheels on the rear and home made "easy side slip" wheels on the front. That gearing was about as high as would work reliably, but we were still using Tekin speed controls that would sometimes shut down temporarilly due to built in overcurrent protection.
If you are running 4WD with four Skyway wheels, and are near max weight, probably 1:6 in high or 1:2 in low would be as tall as you should go. If you are transferring a lot of goal weight to the robot, that might be pushing things.
This info pertains to using drill motors only. Also, other posters may have different opinions.
Team 1062, The Storm, 2003
Unread 02-02-2002, 22:05
AKA: Warthog
I forgot to mention, we had 4 wheel drive. One motor ran two 8" wheels with one chain between them. We were also at 129.9 pounds. we ran with a 2.5 to 1 ratio.
Hope this helps
Wayne Doenges
Unread 02-02-2002, 22:33
Battle Cattle!
These are great but does anyone else have any other opinions?
Kacz
Unread 03-02-2002, 18:54
MI28Driver MI28Driver is offline
#0028 (Mission Impossible)
MI28Driver is an unknown quantity at this point
Send a message via AIM to MI28Driver
ok here is what we have - we have 2 drill motors moving a 4 wheel system. we doubled the 8'' wheels in the front so that the front of the robot has 2 wheels on each side and single 8'' wheels on the back. we use our drills in trans 1 and have a 1:4 ratio , being 18 tooth from the drill to a 48 tooth on the wheels. We never have a problem turning on any surface and can pull over 30 lbs. maybe this can help some people out there.
Team 28 -Mission Imposible- Drive system operator
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
