#16
We have several...
Over the years we have used servos to activate a microswitch on the robot for a program branch jump, to drop an anchor to hold us on a ramp, release a magic tongue and this year we used servos to brake the drive mechanism for our wings (that is what holds them up at the end of the match!) Sometimes you don't need a lot of power, just the will to move. |
#17
At one of the regionals in 2003 I noticed one team (I don't recall the no.) that was using a servos to interface with the Victor 884. The servo was used to activate a switch that was wired to the brake / coaster jumper on the Victor. This enabled the team to actively change the drive system from a dynamic brake system to a coast system. I am not sure what their reasoning was but it was a very clever way to overcome a problem. Simply put the servos can be used to activate switches of all types to suit the needs of the robots.
#18
In 2001 my team used a servo to wave a small American flag back in forth
#19
My team has never used the servos, but we will next year...
Anyway, you can use it to shift gears as many say, or do useless stuff, but I saw one team that put two servos on their lamp and raised or lowered it every time they had to go under the bar. The only problem was it took too long to move one time, and they broke their lamp. You can buy servos withing a huge range of power, from about 5 oz/in of torque to about 1000 oz/in. |
#20
Rookie power
![]() This is really a neat and compact design. We used the plastic drill motor mounts and mounted them to our steel frame. We then added a little L shape piece of aluminum on all four sides to serve two purposes: 1) Mount four small muffin fans to cool our motors down and 2) Support the servo mounts The airflow was superb, we didn't overheat once after they were installed, and being able to switch from high to low gear allowed us to have a quick/precise autonomous mode followed by a powerful low gear. It all worked out nicely =) I would also like to point out that it was one of our wonderful students who designed that little gear-shift mechanism. Hope the picture helps ![]() |
#22
Oh, one more use I forgot about! Some of you may remember Gila III from 2000 (Team 64). We used a servo to release the gate that let out all of the balls in our basket into the trough.
The RED arrow is where the servo is mounted (I know its not very visible) and the BLUE arrow is what it was actually moving. There is another BLUE arrow thing on the opposite side, and it works almost exactly as the gear shifting mechanism in my post above. BTW, that is Mike Rush in the picture... my personal hero, and the man responsible for me being so involved with FIRST ![]() Last edited by WakeZero : 15-07-2003 at 00:54. |
#23
We used a heat sink and heat sink grease on each of our drill motors. This lowered the temp on the surface of the can nearly by half. They worked really great and we never had any overheating problems. Here's where you can buy them and a pic. You should also be able to find them at any quality hobby reatailer such as Hobby Town USA.
As for the colling spray, it is canned air that you buy from Office Depot or Staples or Fry's. When the can is turned upside down, the compressed gas comes out as an ice cold liquid spray. This works very well for cooling the CAN of the motor between matches. It is also very useful for cooling breakers before matches to ensure that they don't trip as much. The reason I'm telling you all this is from something Andy Baker said that I agree with: Quote:
PS. Sometime hopefully before the end of the summer I will have a little white paper made of "Tips, Tricks, and Field Side Fixes" that will cover the things above and much more. Last edited by sanddrag : 16-07-2003 at 22:48. |
#25
My post above got posted without being complete
, it's all edited and finished up now. ![]() |
#28
As for the cooling fans, I forgot to mention that they are all pointing in the same direction. So you have: Fan --> Motor --> Fan The arrows represent the airflow, and the left fan brought in the cool air while the right fan sucked out the hot air. I can see your point about just blowing cool air onto the casing, but we actually took the hot air out ![]() It may not have made a huge difference, but we did notice that after we installed them we never overheated like we did a couple times before ![]() |
#29
| pic: creative shirt | CD47-Bot | Extra Discussion | 3 | 17-03-2003 23:08 |
| FIRST and Creative Mediums | archiver | 2001 | 1 | 24-06-2002 04:11 |
| Hi Colleen | archiver | 2000 | 2 | 23-06-2002 22:03 |
| weight advice | SharkBite | Technical Discussion | 36 | 15-02-2002 07:30 |
| User Titles | Brandon Martus | CD Forum Support | 27 | 04-06-2001 22:23 |
