#31
Or maybe our motors didn't heat up because we never liked to get into pushing fights with our top-heavy stacker. We're afraid. ![]() |
#32
Some of that canned "air" is really a refridgerent known as R152a (difluorethane). When it is released it expands, and that is what does the cooling. Works just like your AC at home, except it's a different refridgerant.
By the way, even though it is not classified as "flamable", it burns like crazy when you light it. I've done tests... my "lab" wall has burn marks to prove it. |
#34
Okay, let me rephrase my idea.
My original comment was that our team's motors didn't heat up because we used the drills + chippies. And that they help each other out to not overheat. Most robots draw the most current while pushing other robots, and more current results in more heat. They draw even more current because their wheels stop spinning sometimes if they only use the drills. We used 4 motors, and if you run the robot into another, (or into a wall) the wheels will burn away freely at the ground, preventing the motors from stalling out and drawing crazy current. Meaning that if you used more motors, they provide enough power together so they can never stall out. Gearing this kind of system for speeds upward of 15 ft/sec could result in stall since they aren't geared for power at such low speeds. But few teams actually did use similar gearing. |
#35
If you do it just right you can attach a q-tip to the end and use them to clean your ears..
wow.. he said creative |
| pic: creative shirt | CD47-Bot | Extra Discussion | 3 | 17-03-2003 23:08 |
| FIRST and Creative Mediums | archiver | 2001 | 1 | 24-06-2002 04:11 |
| Hi Colleen | archiver | 2000 | 2 | 23-06-2002 22:03 |
| weight advice | SharkBite | Technical Discussion | 36 | 15-02-2002 07:30 |
| User Titles | Brandon Martus | CD Forum Support | 27 | 04-06-2001 22:23 |
