Go to Post The easiest and most effective way to do this for the Championship event is pre-competition scouting, with statistics. Nothing beats it. Hands down. Period. The End. Nothing's better. - Tom Bottiglieri [more]
Unread 17-07-2003, 13:30
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
VB .Net Question
I've searched MSDN, Google, and Yahoo for this, asked people, but still haven't really got anything.
What I'm trying to do is figure out how to create a new line (i.e.: In C++, \n makes a new line). But can't find out how to do it.
I've also searched the help document that comes with Visual Studio .NET (the one that FIRST gave us).
If anyone knows how/if it is possible to do, please tell me.
[Edit: Also, how would you load another form?
EX: In VB6, you do
PHP Code:
*form name here*.visible true
How do you do it in VB .NET? ]
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 17-07-2003, 13:59
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Search harder.
It's there.
Typically a new line consists of a line feed function and a carriage return function. Some languages have them combined.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 17-07-2003, 14:54
AKA: Eric Hansen
Originally posted by Jnadke
Search harder.
It's there.
Ok, thanks. I found what I wanted:
PHP Code:
System.Environment.NewLine
Y!: synsoflife
Unread 17-07-2003, 15:48
FRC Key Volunteer Trainer
AKA: CrazyNate
Re: VB .Net Question
EX: In VB6, you do
PHP Code:
in .NET, it's a bit trickier. The catch to remember is that every form in VB.NET is considered an object. Now, I think all the code below is correct, but I don't have .NET on this machine right now to try it out...
PHP Code:
Dim frmShowMe as frmFormToDisplay
frmShowMe
= New frmFormToDisplay
frmShowMe
.Show
Nate Smith
nsmith@smythsoft.com
Unread 17-07-2003, 18:16
AKA: Eric Hansen
Re: Re: VB .Net Question
PHP Code:
frmShowMe
frmShowMe
.Show
Actually, you are almost correct.
It's
PHP Code:
Dim frmholder as new frmtodisplay
frmholder
.activate()
frmholder.visible true
There's only 1 problem w/ this, if you close out of it, and try to show the frm again, it crashes.
Y!: synsoflife
Unread 18-07-2003, 09:27
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
If you want to open a form named frmSetup:
Form setupForm = new frmSetup();
frmSetup.Visible = true;
frmSetup.Activate();
if you want to open it as a modal dialog:
frmSetup.ShowDialog();
The only issue with the first method is that unless you check to see if the form is already open, you'll have multiple instance of the same form floating around. The difference between the Show() and Activate() methods is that Show() just makes it visible, but Activate() brings it to the front. Activate() only works if the form is visible, so you need to set the Visible property first.
Unread 18-07-2003, 10:26
AKA: Eric Hansen
Welp, that explains the crashing. Thanks seanwitte. Is opening it as a modal dialog better than using the activate() one?
[EDIT: Using the ShowDialog() doesn't cause a crash in the program (hurray!).]
Y!: synsoflife
Unread 18-07-2003, 10:45
None #0116
A modal dialog will keep the focus until you close it. If FormA opens FormB as a dialog, then you can only interact with FormB until you close that form. For most cases its probably fine, normally you'd use it when you need input before doing something else. You are forcing the user to commit or cancel some operation before they can continue.
If you need two forms open at the same time with the user jumping between them then you need to use Activate() or Show(). The Show() method is the equivalent of setting the Visible property to True BTW.
Unread 19-07-2003, 13:36
AKA: Eric Hansen
Ok, my program (more specific, a dash-board program) is coming along nice. I have yet another question though. Is it possible to have 2 forms show up, and dock the 2nd one to the first (like what AIM can do with the edge of the screen).
I've got this:
PHP Code:
switch.dock dockstyle.right
(switch is already defined). It shows and everything, but I want it to be visible (not behind the main form) when the program starts (for a more clear example, look at roboEmu (http://www.robbayer.com/software.html) program to see what I mean).
Y!: synsoflife
Unread 19-07-2003, 22:32
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
I've got this:
PHP Code:
A few things to start off with:
1. Traditional docking involves docking one window inside another.
2. Docking to the edge of the screen (AIM style) and docking one window to another (a-la Winamp) are two very different things.
3. RoboEmu doesn't actually use docking. I just tell it to put the Windows in the right place to start. It's up to the user to keep them that way.
Anyways, I don't really know much VB, but from what I've been able to discern, getting a window to dock to the outside of another one is not an easy task. A quick google search turned up this: http://www.visualbasicforum.com/t54802.html
Unread 20-07-2003, 10:32
AKA: Eric Hansen
Thank you rbayer, I didn't know there was a difference (much) between Winamp-style and AIM-style.
And sorry about he RoboEmu thing....I thought you docked the windows.
Y!: synsoflife
Any pratical use for Microsoft Visual Studio .NET Pro Kyle Fenton General Forum 11 28-01-2003 16:59
White Paper Discuss: VB .NET Dashreader custom control source CD47-Bot Extra Discussion 2 19-01-2003 19:32
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
VB Program to monitor robot variables DanL Programming 7 15-02-2002 22:35
