Go to Post The sword is only as powerful as it's beholder. But if you choose the labview sword you won't get much tech support at regionals. - xXhunter47Xx [more]
Go Back   Chief Delphi > Announcements
Unread 30-07-2003, 22:54
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Use of the AKA Profile Field
The AKA field should contain your name, if you want. If your username is your name, then you can put your online screenname / nickname.
The AKA field shouldn't contain a silly phrase or sentence. That is what your signature is for. There is plenty of room there.
Leave the AKA field blank if you are not going to put your name or a nickname in it. The moderators and I will be clearing out the AKA field for you if there is a violation of the above two rules. If the abuse continues, the field will be disabled for your account.
The field is not being used as it was intended, so these rules had to be made. The site rules have been updated accordingly.
Thanks.
Brandon Martus
e-mail
The AKA Profile Field. Brandon Martus CD Forum Support 17 01-08-2003 18:54
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
Looking for full playing field archiver 2001 1 24-06-2002 00:13
Lego field wanted--URGENT!!! David Kelly General Forum 0 19-11-2001 12:17
