Go to Post Capability and willingness are two very different things. Anybody can dance, though you could spend your lifetime unsuccessfully trying to convince them of that. - Mr. Pockets [more]
Unread 04-02-2002, 15:34
316_programer 316_programer is offline
#0316 (LuNaTeCs 316)
316_programer is an unknown quantity at this point
Exclamation Analog Inputs
Hello all,
I have a problem, I don't know how to get data from the analog inputs. any info. would be helpful.
Team #316 (The LuNaCeCs)
Unread 04-02-2002, 20:12
Matt Reiland's Avatar
'The' drive behind the drive
You need to first wire it according to the manual (correct pins +5, GND, and the signal) Go to the initialization area and for the sensor you want to read make it CON 1. Then add the sensor you are using to the serin command (Sensor 1 and up). Presto you have the data.
email me if you have any problems
Matt
Unread 05-02-2002, 05:53
Lloyd Burns
Check out this little tutorial:
How to enable the RC Analog Inputs
http://www.team188.com/cr/forum/tech...sages/51.shtml
How to access other Digital inputs on OI? DougHogg Electrical 2 12-03-2003 13:57
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
Serious Controller Ideas archiver 1999 28 23-06-2002 23:01
