Go to Post One of the many unwritten laws of engineering failure is that the problem will occur in the most inopportune time. - Dave Scheck [more]
Unread 05-08-2003, 13:46
lkeller lkeller is offline
#0857 (Superior roboworks)
lkeller is an unknown quantity at this point
Question PC Interfacing
I heard somewhere that It is possible to interface the Basic stamp through one of its ports (i think the dashboard port) to a PC and that one could actually outsource proscessing to the PC. I was wondering if someone could point me in the wright direction. I was basically under the understanding that one could wright code on a pc and then use the PC to read from the stamp's imputs and then send comands to it. Is this true? A little help?
Thanks
Unread 05-08-2003, 17:18
FRC Key Volunteer Trainer
AKA: CrazyNate
Only partially right..
YES, you can connect a PC to the dashboard port and read back certain values from the RC->OI data stream. However, you have no (legal) way to send data back to the OI.
Nate Smith
nsmith@smythsoft.com
Unread 05-08-2003, 17:45
Matt Reiland's Avatar
'The' drive behind the drive
Not even sure if you would want to use a PC in the scheme shown since you would have the delay of the wireless interface.
A better bet would be to offload some computation to a second microprocessor through the programming port, similar to what allot of teams did this year for positional data. Search for interfacing to second micro.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 06-08-2003, 00:06
Are you looking for a solution that is legal to use on a competition robot, or just something to mess around with?
Rob Bayer wrote a program that will control the robot via PC. http://robbayer.com/robocon.shtml
If you are looking for something that is competition legal, you will need to buy a microprocessor/SBC from digikey or future active. You can then interface the two through the programming port.
Unread 06-08-2003, 09:51
Umm Errr...
Are you looking to connect the PC to the OI or RC?
1139 Alumni
Interfacing a second Micro to the RC Matt Reiland Programming 3 08-06-2003 00:11
