Thickness of aluminium bars
HI guys,
I was just wondering, is there a maximum thickness to the aluminium bars/sheets that we're using? Thanks. |
I believe the max thickness is 1/4" for the plate as for the tube which is probably considered an extrusion its something like 2X3" max and you can have whatever thickness you want
Check both them for sure in the Additional Hardware section |
| Question about Plywood thickness | KennethToronto | Technical Discussion | 4 | 06-02-2002 15:20 |
| gear thickness | zarb | Technical Discussion | 10 | 26-01-2002 22:07 |
| Aluminium Clarification 10-10-01 | Mike Martus | OCCRA | 3 | 18-10-2001 07:55 |
| Aluminium Clarification | Mike Martus | Off-Season Events | 2 | 11-10-2001 10:17 |
