Speed is pretty much relative in this game. It is more or less dependent on what sort of strategy you are doing. If you are going after the goals and intend on pushing them, 2 -3 fps is probably about right. If you intend to run around the field and pick up balls, then 6+ fps is about right. Keep in mind that speed is only part of the game. Going 10 fps won't do you much good if you can't push the goals around.
Jeremy Team 401 |
| initialization program and speed controllers | rosebud | Programming | 15 | 05-10-2004 03:35 |
| "Automatic Transmission" | Madison | Technical Discussion | 70 | 24-11-2003 09:03 |
| Power, speed, and torque... AGH | Gui Cavalcanti | Technical Discussion | 5 | 10-11-2002 19:02 |
| 322 Three speed transmission. | dkeith | Robot Showcase | 8 | 10-06-2002 22:33 |
| Calibrating speed controllers and joysticks | thedillybar | Technical Discussion | 4 | 11-02-2002 13:24 |
