Go to Post When twenty people tell you your hair is on fire, you don't need to look into a mirror to find out they're right. - IndySam [more]
Unread 04-02-2002, 19:50
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
We had zero problems with the SPI couplings.
We used a 1/8" keyway on the drive shaft to mate with the keyway in the coupling and a 1/16" Steel roll pin on the drill motor shaft (threaded end) as specificed by the SPI documentation.
We have not experienced any problems and have been testing (beating up) the drive train for about 1 week now.
We should be ready for FULL bot testing (read FULL WEIGHT) within the next 2 days. I'll be sure to post any problems if they arise.
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
3.5x3.5 coupling? ahecht Technical Discussion 1 05-01-2002 23:36
