Go to Post What should the lesson of FIRST be? Work within your resources to build the most effective machine that you can--and, at the same time, work to increase those resources. - Billfred [more]
  #91   Spotlight this post!
Unread 11-08-2003, 20:51
Alfred Thompson's Avatar
Alfred Thompson Alfred Thompson is offline
Adult troublemaker
FRC #0811
Alfred Thompson has a spectacular aura aboutAlfred Thompson has a spectacular aura about
Send a message via AIM to Alfred Thompson
Originally posted by Matt Krass
You cannot directly compare any language like that, it depends on the situation and you cannot outright say one is horrible and the other is fantastic. For example FORTRAN will blow away most languages in math crunching, even C#. But C++ can devastate VB in efficency when used properly. It's not as simple as one is good and one is bad.
Well it's not simple but I think that you can say that some languages are bad. At least on a reletive scale. When one compares OOP languages for general programming they can pretty reasonably say that Java and C# are much better then C++. Both Java and C# correct major problems with C++ and make for safer programming.
And performance often depends more on the unerlying runtime and associated libraries then on the language itself. FOr example, a lot of the really graet mathamatical things that people do with FORTRAN are do more to special libraries that have been developed for use with it then the language itself. Plus there are special purpose additions to the langauge for array processors that have been added to FORTRAN largely for historical reasons (math guys like FORTRAN) then necessaty. IF the same extensions were added to other languages they would be faster too.
Take a look at other languages as well. The JVM is slow. Someone came out with a much faster one and Sun sued the company that made it and forced them off the market. IF that hadn't happened maybe Java performance would be bettter. And the performance of VB improved greatly when the unerlying platform was upgraded to .NET. So I would not use performance as the key to what is a good language.
What you look it is things like being type safe. Like having syntax that makes it easy to create the kind of programming structures you want. And things that are basic to the language.
  #92   Spotlight this post!
Unread 11-08-2003, 21:28
Umm Errr...
Im getting antsy. I just wish they would go ahead and tell us.
1139 Alumni
  #93   Spotlight this post!
Unread 11-08-2003, 21:30
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
I hope it sticks with PBASIC though honestly....or else my whole project will be a waste of time (and HD space).
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
  #94   Spotlight this post!
Unread 11-08-2003, 21:42
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Don't bet on it...
Jeff Waegelin
  #95   Spotlight this post!
Unread 11-08-2003, 21:45
AKA: Eric Hansen
Originally posted by Jeff Waegelin
Don't bet on it...
You got some insider scoop? (j/p).
I don't really see why not....every programmer that's been in FIRST for 1 year knows it, and every new programmer can catch on pretty fast basically.
I'd be better, because then mentors and whatnot don't have to teach every programmer a new language. If they have no internet, then they're basically screwed then.
Y!: synsoflife
  #96   Spotlight this post!
Unread 12-08-2003, 01:29
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
I've been told that the new system will have all of the same functionality as the PBASIC interface.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
  #97   Spotlight this post!
Unread 12-08-2003, 08:37
AKA: Eric Hansen
Cool. I hope it does. Maybe it'll be ZBASIC? (lol, that'd be scary if it was).
Y!: synsoflife
  #98   Spotlight this post!
Unread 12-08-2003, 08:47
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Java and C# are not inherently better than C++. Anyone who told you as such doesn't know what they're talking about. Java, C#, and C++ all have their various advantages. Java is very good at being cross platform (much more so than C# contrary to what Microsoft would have you believe). C# is very good at Windows development (even if it isn't particularly mature). C++ is very good for large projects that require speed, low memory requirements, or device level programming.
Basically, it comes down to using the correct tool for the job. Sometimes C++ is correct, sometimes it's Java or C#. Other times it's assembly (in fact, I'm starting a project at work with assembly as soon as the developer's kit arrives). Sometimes you need to use straight C or possibly Perl or Lisp. There is no one programming language that is better than the others.
Matt
  #99   Spotlight this post!
Unread 12-08-2003, 12:41
AKA: Eric Hansen
Originally posted by Matt Leese
...Basically, it comes down to using the correct tool for the job. Sometimes C++ is correct, sometimes it's Java or C#. Other times it's assembly (in fact, I'm starting a project at work with assembly as soon as the developer's kit arrives). Sometimes you need to use straight C or possibly Perl or Lisp. There is no one programming language that is better than the others.
Matt
It also depends on what you are more comfortable with. Like the debate between OpenGL vs DirectX or the Win32 vs MFC. Arguments are fine, but none are the #1 answer. Both have pro's and con's, just like everything else. If you're making a game, use what you feel more comfortable with. Making an IDE? Use whatever you feel comfortable with. It's like FIRST, this year there were debates in every team probably about which kind of bot to build. Some said Stacker, some said pusher, and probably other types were brought up.
>> Sorry <<: I had to use the FIRST comparison, it kinda cleared up what I was saying.
Y!: synsoflife
  #100   Spotlight this post!
Unread 15-08-2003, 23:53
One thing said above that is true is "it depends on ..." who's writing, and what is being programmed. It also depends on the hardware in some cases.
I quickly scanned the thread, but don't see any mention of the Javelin Stamp - "A 24 pin processor programmed with a subset of the Sun Microsystems Java language", as they say on the Parallax.com site.
This means Stamps (read familiar-to-IFI processor) can talk in PBasic or Java. This might rule out APL or COBOL as possible languages for next year, as well as Forth.
  #101   Spotlight this post!
Unread 16-08-2003, 00:12
Adult troublemaker
FRC #0811
Matt
I'll tell them to give back their PhDs in computer science then. No doubt you've got a lot more experience in programming then them or me.
  #102   Spotlight this post!
Unread 16-08-2003, 14:00
Umm Errr...
This really is a very stupid arguement. USE THE RIGHT TOOL FOR THE JOB. And this thread has gotten rather off topic.
1139 Alumni
  #103   Spotlight this post!
Unread 16-08-2003, 14:21
El Jefe de 148
Agreed. It's turned into just argument about C++. While I will say your topic is somewhat relevant, if you'd like to continue the discussion, I suggest you take it out of this thread, so it's not distracting the real discussion.
As for my "inside sources," let's just say I have information from two very reliable, well known sources that say we may be dealing with a new control system that doesn't use PBASIC, provided that IFI can make enough for the 2004 season. Whether we'll "C" this controller next year or not remains to be seen... but my sources say we will
Jeff Waegelin
  #104   Spotlight this post!
Unread 16-08-2003, 16:04
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Well actually even if they decided to go with just plain basic or another variant of it should be easy to convert it to that. I personally hope that it turns out that way. Most of the basic compilers out there either sport compatibilty with pbasic or share similar commands while improving upon it.
  #105   Spotlight this post!
Unread 16-08-2003, 17:20
AKA: Eric Hansen
True....I didn't really think about that when I posted it. My other argument is the tokenizer.dll. Will they still use that, or is it gonna be another library.
Y!: synsoflife
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Championship Qualification - How you would've done it Ken Leung Championship Event 6 26-10-2003 14:00
Making heads or tails of the new announcement... Jessica Boucher General Forum 66 26-09-2001 11:13
TI programming using Z80 assembly language Jeff Wong Chit-Chat 1 07-06-2001 01:27
