| Thread Tools |
Rating:
Display Modes |
#106
I wander what cool new hardware features there will be. I hope there are more io ports such as some general purpose bidirectional ttl or cmos compatible pins and a real lcd.
#107
Plus, I've met a good number of people with PhD's who really don't know what they're talking about. Or at least don't have as good an understanding as they should. Matt |
#108
But in general terms you can say that one language has more good features then another and/or that one language has more bad features then another. And clearly for general applications Java and C# are MUCH better languages then C++. Of the 9-10 languages I've used professionally (and a bunch more for fun) C++ is in the lower middle of the ones I'd use again if I had the choice. Above DIBOL and below OOP COOBOL .NET. |
#109
But Matt is right. C++ is recommended over a lot of langauges for 3D programming. You wouldn't use VB for it, because that would make it run to slow. I'm not sure if C# can do 3D. ASP can't handle 3D at all. Nor PHP. C might. But still, read my sentence, and repeat that over and over (repeate the stuff inside the quotes that is) if you don't know what language to use for a project. Heck, I'm using MFC for my editor (I was using the C++ Win32 API, but that was causing more confusion than anything). MFC is great for what I wanna do. But it isn't to good for making games. |
#111
Are you saying that no language is better then any other? They're all the same? |
#112
Neither of the two camps in this argument is going to convince the other that either one is right or wrong.
Don't get me wrong. I have an opinion, which I have, more or less, already expressed. I don't claim to be an objective observer. I just am all too familiar with arguments like this. One suggestion: drop it. So, about that new control system... I've heard that teams will have the ability to use the same syntax as we've all been familiar with, for past years, in PBASIC. I assume this is a fall-back-plan for teams who can't cope with such a fundamental change, so quickly (possibly analogous to what some teams experienced with the introduction of an autonomous mode). What do you think the chances are that they (IFI) would use a product like a PICBasic compiler, rather than develop the translational software in-house? |
#113
I think there may be a more likely solution in that software written in PBasic may run in an emulation layer on top of another processor. If the processor was significantly powerful (and frankly, it's not hard to get a cheap powerful processor these days), it wouldn't be too difficult to do that. Another possibility is to just have two different chips on the board (both a Basic Stamp and some other mystery chip) and it's user selectable as to which one is used. Matt |
#114
Hmm. Thats a good point. It, however assumes a relatively powerful processor like a StrongArm Coldfire, etc. Most higher power processors must be either programmed in assemble or a compiler must be used. That would mean that FIRST would have to get a company such a MetroWerks donate the software. Microsoft and Metrowerks? not likley On the other hand I think it is highy likley that they will use another Basic stamp like chip, such the Basic Atom, Basic X, etc. This would allow a great boost in power, with little syntax change. While a real(ie: runs compiled code) processor would be nice, I think we will probably just see another Basic Stamp like chip. I hope im wrong though. |
#115
As far as having MetroWerks donating a compiler, I wouldn't see why not. They are owned by Motorola after all which is a big sponsor of FIRST. That leads me to another point: I think there's a strong possibility that the new chip may be from Motorola. Motorola makes a lot of embedded chips and may be willing to give IFI a discount on them for use with FIRST. The chips are widely used and have a lot of support out there. There are also various C compilers for the processors. I think that may be a strong possibility. Matt |
#118
please if motorola does wind up working with or without ifi on a new IO and/or RC please do not have it like another big, bulky, space wasting, White box like it has been in the past.
~Mike |
#119
interpretors-An interpretor reads a high level language and then tells the micro-controller what to do. It is almost exactly what a Basic stamp does. The slowest of the three choices due to the fact that the microcontroller has to read the high language. Compilers- Compilers turn high level languages and turns it into assembly. They generally have to be designed for a specific brand of micro-controllers since each one usually has different hardware architectures. The second fastest due to the fact that the program is being translated into assembly. Assembly- Lowest level language for any microcontroller and generally the hardest to understand. The fastest one if properly implemented. Usually all that gets affected if you go from one type to the next is the speed of the program. It usually goes like this in order of increasing speed: interpretors<compilers<assembly Last edited by Adam Y. : 20-08-2003 at 09:42. |
#120
I think it's java...anyone look up parallax's latest projects...the javalin stamp...the basic stamp...I don't think it would be too much work to replace pbasic with java by switching stamps from the same company. Likewise, I would think parallax would be pressuring IFI to be using the javalin stamp to promote sales and usage. The AP Compsci switched from C++ to Java. Will everyone taking AP Compsci right now not be familiar with java by the time it is released? In addition, Java is more practical than PBASIC pertaining to the real world. No one cares that someone programmed in PBASIC but atleast with java you earn some respect. Java is also cross-platform, I would think if they move to Java they would also support a cross-platform pbasic editor written in java..
I prefer C++, but I'd still want java over pbasic anyday. |
| What is your most prefered programming language? | Hailfire | Programming | 156 | 19-01-2005 21:42 |
| 2004 Championship Eligibility Criteria!!! | dez250 | General Forum | 214 | 28-12-2003 20:11 |
| Championship Qualification - How you would've done it | Ken Leung | Championship Event | 6 | 26-10-2003 14:00 |
| Making heads or tails of the new announcement... | Jessica Boucher | General Forum | 66 | 26-09-2001 11:13 |
| TI programming using Z80 assembly language | Jeff Wong | Chit-Chat | 1 | 07-06-2001 01:27 |
