Go to Post Go fish, dude. - Bill Gold [more]
Unread 17-08-2003, 13:32
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
PBASIC Syntax Question
I'm not sure why this happening, but in my PBASIC editor, whenever I try to download the code (for testing), it always returns an error "201 - Expecting '}'", and here's the only thing I have in the code:
'{$STAMP BS2}
Even when I use the default code given, it still returns this error.
Anyone have an idea why this is happening?
<<EDIT>>: If I use the code from RoboEmu (File -> Write Code) in my program, it gives this error, but in the Parallax one it is perfect :<</EDIT>>
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 18-08-2003, 13:18
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
You're talking about the editor you're writing, right? My guess is that you're sending the wrong buffer length to the tokenizer.
Unread 18-08-2003, 13:33
AKA: Eric Hansen
Yes, I am
I don't know if this will help, but here is the code I use to tokenize the code:
void CMainFrame::OnDlcode()
	CMainFrame *pFrame = (CMainFrame*) AfxGetMainWnd();    // Get frame window class
	CFIRSTEditorView *pView = (CFIRSTEditorView*) pFrame->GetActiveView();
	char *szBuffer = new char[66356];
	// Use if below fails to do memory right: char *szBuffer = new char[pView->GetWindowTextLength()];     // New 'char' pointer array based on window text length
	pView->GetWindowText(szBuffer, pView->GetWindowTextLength());     // Get view window text
	tModRec.SourceSize = strlen(szBuffer);
	Compile(&tModRec, szBuffer, false, true);
	if(tModRec.Succeeded == true){
		StatusBarMessage("Tokenize successful!"); // Tell the user it went smoothly
	else{
		StatusBarMessage(tModRec.Error);
	delete [] szBuffer;
char *szBuffer = new char[66356]; <-- 66356 is max amount of text that the TModuleRec source buffer can hold
pView->GetWindowText(szBuffer, pView->GetWindowTextLength()); // Get view window text <-- For some reason, I got a feeling it has to deal w/ this, or the szBuffer part.
This is in MFC also.
<<EDIT>>: I forgot to say that I was using the wrong way to do the STAMP, it's ' {$STAMP BS2p}, not ' {$STAMP S2p} :<</EDIT>>
Y!: synsoflife
Unread 19-08-2003, 23:46
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Are you sure szBuffer contains the whole thing? Trying doing a
MessageBox(NULL, szBuffer, "Test", MB_OK);
and see what it spits out.
Unread 20-08-2003, 08:07
AKA: Eric Hansen
Sadly, it doesn't << cries >>.
Thanks for the help on that (should've known to do a test on that). Now to figure out why (which I have an idea).
<< EDIT >>: I found out why...it was because of the SETSEL LPARAM section was probably to small, and plus I needed a space after the '}' in my code for it to register it (argh!)
<< EDIT 2 >>: I can get it compile or whatever way you think of it (tokenize). Now, does anyone have a thing on making a progress bar move? (Sorry, MSDN is really buggin' me right now). If you wanna know, I used to get the 157 error. But I had to set the first compile boolean to true in order to tokenize successfully. Thanks for all your help people
Y!: synsoflife
PBASIC language syntax WizardOfAz Programming 14 30-04-2003 10:23
Question Obtaining Pbasic 2.5 PyroPhin Programming 3 18-01-2003 01:26
pbasic question Mike375 Programming 14 15-01-2003 06:54
PBasic Question Melissa H. Programming 28 17-11-2002 18:53
Another PBASIC Question Ian W. Programming 4 31-01-2002 21:36
