Go to Post A good teacher always needs to be a good student - Redhead Jokes [more]
Unread 27-08-2003, 10:01
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Drill motors
How many drill motor should we get next year?
"I'm sorry, after all he is just a wookie!"
Unread 27-08-2003, 10:43
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Two more than we need.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 27-08-2003, 21:20
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
I think that 2 is enough. 2 is enough for rookie teams to have a simple powerful robot. If you gave them 4 then there wouldn;t be a need for teams to make shifters and let the creativity really flow.
Unread 28-08-2003, 00:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The need for shifting is not based on the motors you have or how many of them simply because everyone gets the same motors in the same quantity. The need for shifting comes from potentially having something better than many other teams.
Unread 28-08-2003, 01:06
In Hibernation
#0481 (DART)
yes, but the drills have built in shiftable gearboxes. And i didnt mean only shifters, i mean i made a gearbox for the chippys that didnt shift. That would not have been required if four drills were provided.
Unread 28-08-2003, 08:55
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
How would just having 2 more motors make shifting gears not required? If you think about it then people could have 2 drills and an atwood per side on their drive. Now your saying that drive locked into 300rpm is just as strong as the same drive with a shifter capable of 300 or 100rpm? As was said...the main reason some teams make a shifter is to give them that edge over other teams who are locked into 1 speed. Not to mention shifing to a lower ratio reduces the current draw and lets you push against other robots without worry (most the time)
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 28-08-2003, 08:57
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Well, 4 drills would make swerve drive a whole lot easier; perhaps too easy. If you have 4 identical motors, like the drills, you could just put one on each wheel, and not have to worry about matching speeds between two dissimilar motors.
Jeff Waegelin
Unread 28-08-2003, 10:28
Matt Reiland's Avatar
'The' drive behind the drive
While I don't know if it would make it a 'whole' lot easier
(since you need to already make your own gearboxes for swerve anyway so changing the last stage to match the motors wouldn't be that hard) The FP and Atwoods are somewhat simple to match to the FP’s as described in many documents.
It does make the design much more common as you can have 4 (or 2 of L/R) identical interchangeable modules with the same motors. I think it would make a very nice powerful swerve robot. The hardest part to swerve in my mind is the control of 4 gearboxes both in steering, power levels, and the operator control system.
If we got 4 of the same drills……. I would probably put 2 of them together on each side with the Atwoods to make a monster shifter gearbox with incredible power and redundancy. But that’s just me.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 28-08-2003, 13:14
Granted, designing and fabricating four of the same gearbox, instead of two each of two seperate designs, can be easier, but it depends on what a team's resources are. Either one could be trivial for a team with professional machine shop support, while a team without that support would probably want a standard design that they could copy for replacements.
I agree with Matt Reiland, however, in that the control system for a swerve drive is probably the more involved part of the design / manufacturing process. Speaking from experience (and I wasn't even the one programming the thing), testing and bugfixing and calibrating and recalibrating and compensating for hardware in software, etc., takes a lot of the time allotted to you for such a project as this.
Unread 28-08-2003, 20:42
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Actually almost all designs can get through with using just a pair of similar motors for drive. You would just need another motor for steering.
Ackerman-Don't need a pair but it will improve power if you do use two of them for drivetrain.
Differntial-It will work with just a pair of drill motors.
Synchro Drive or Crab Steering-I have thought about it. You probably could make do with just two drill motors and have the others just free wheel.
The only one where you need more than two motors is the holonic or omni wheel deising.
Unread 28-08-2003, 21:56
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
along the lines of what he said,
4 identical motors, on a standard tank drive, that would give you a lot more power, saves a lot of time with building coplicated drivetrains, alows more fancy/ complex designs for other things on the bots.
It would make drive train construction easier.
Or 2 extra drills wold give you more powerful mechanisms, other that drive.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 02-09-2003, 01:33
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
just consider this the more motors you get, the less weight you'll have for other things b/c motors have weight and even though the speed controllers for them / wiring doesn't weigh that much that 1 ounce over could hurt your quailifications for a Comp. espicially if FIRST sticks to the 130lbs. 1 more motor would be a lil better 2 would make it to simple and designs for drive train would be near but not quite similar. 3 drillls for drive train would make things a lil more interesting and 2 drills would bring out some awesome designs. like it has done so in the past couple of years so either.
A: keep the amount of Motors the same
B: Add an additional motor
C: Add an additional 2 motors. and suffer possible weight constricting / restricting designs
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 02-09-2003, 09:32
Just because you get two more motors doesn't mean you have to use two more. It's just nice to have more options. And as for wiring weighing less than 1 ounce, I don't think so. Especially not with 8 guage to all 4 drive motors.
Unread 05-09-2003, 22:43
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
I've said this in some other post, but adding another 2 motors of the same kind would make things too easy. Notice how only 4 motors are practical for drive trains? And they are 2 different types. Last year, you could have added the fischer prices and got about 2/3 more horsepower, but that's a challenge to do. Giving us 2 more drills gets the horsepower a little past 3, and it's pretty easy to modify last year's 4 motor to a 6 motor. FIRST wants to give us a challenge. If you want to make a better drive train, make one with 2 or more gears, or a swivel or whatever. If you are just going for more power and not complexity, ask yourself this: do you really want a battlebot? None of FIRST's games involve a robot that is only one big drive train. And if you are looking for an advantage while pushing another robot, you must remember the physics involved. A robot can only exert as much force on the ground as the wheels can permit. The equation is :
power on ground = traction of wheels x weight x power of motors
Since all robots are 130 lbs or close, it fully relies on traction and power. Most robots with 4 motors can drive up against a wall and burn out their tires, so it is the traction of the wheels that gives up first. Work on better traction, not more power. A robot with 2 drills and high traction will always beat a robot with 10 drills and medium traction. It's just a matter of how much of your motors' power you can deliver to the ground. But hey, I guess you can always dream about more motors
Unread 06-09-2003, 04:33
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Actually, thats exactly what the last two year's games have involved
Cory
2001-2004: Team 100
2006-Present: Team 254
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
Blowing drill motors archiver 2000 6 23-06-2002 21:58
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
