Go to Post No caffine for you! - Koko Ed [more]
View Poll Results: Should Weigh in be With or Without Battery
With 31 55.36%
Without 19 33.93%
Weight Limit should be increased to make things more exciting. 6 10.71%
Voters: 56. You may not vote on this poll
Unread 04-09-2003, 22:22
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Originally posted by sanddrag
Oh, and don't try to place your toe under the scale and lift up while your robot is being weighed. They look for that too. (although it is helpful and okay to fudge with it a little up and down before the actual reading is taken to ensure an accurate measurement.)
That may be a good idea.
Last year we were weighting the robot in Seattle and the scale would range from 130 to 130.5, so *someone* (was it me? ) had the brilliant idea to empty the air tanks to see if it would help - heck, the air above us weights a whole lot .
Well, the scale actually went half a pound up... Go figure
"And the robot got some nice speed holes..."
Manoel Flores da Cunha
Brazilian Machine
Team # 383
running bot off car battery? Trashed20 Electrical 25 06-06-2003 12:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
