Go to Post Sometimes, you just have to beat something (someone?) into submission. Yes, you can use your head, but its a lot easier with a hammer. - Andy A. [more]
View Poll Results: Should Weigh in be With or Without Battery
With 31 55.36%
Without 19 33.93%
Weight Limit should be increased to make things more exciting. 6 10.71%
Voters: 56. You may not vote on this poll
Unread 05-09-2003, 12:45
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Originally posted by Manoel
The "official battery" idea would also help to check the "is the battery easily removed" item from the inspection, plus, 130 is a nice round number to play with, eh?
It's pretty easy to tell just by looking at the battery compartment on a robot if it's easily removed. However, an "official battery" won't really solve any problems - when you have 4 or more weigh-ins occuring at the same time (some regionals have 2+ scales, the Championship has at least 4 scales), you'd need 4 "official" batteries. And guess what? It would be very likely that there'd be minor variations between the 4.
In that regard, the scales at the Championship seemed to vary by up to 1/2 pound anyway, so there's already a lot of "slop" in the whole weigh-in process. I don't have a problem with people weighing in with the lightest battery they have (as long as it's still a legal battery). There's no rule against it and it only gains them a marginal amount of weight anyway. If there really are teams that would stoop so low as to weigh in with a hollowed out battery, then those teams will find a way to cheat one way or another, making this somewhat of a moot point.
running bot off car battery? Trashed20 Electrical 25 06-06-2003 12:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
