Go to Post The ChiefDelphi forums are more than just a place for people to kill time and engage in some chit chat. - Karthik [more]
Unread 06-09-2003, 16:06
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
The Skyway 9x2 Bead-Lok wheels really do suck UNTIL you turn them down on a lathe to have a flat profile. This gives really good traction (even though they are smooth) on carpet while still allowing enough sliding for 4wd tank style turning.
I really would not recommend really modifying those tires much. It looks like they have a tendency to disintegrate a lot and really do not stop if they start too.
Unread 06-09-2003, 16:12
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Originally posted by sanddrag
Now, another interesting concept I saw at the SCRRF scrimmage was a team that used the FIRST provided chassis, but added two more helical gearboxes at the other end of the robot and had a shaft running down each side of the chassis linking the two for 4 wheel tank drive. That was really cool.
That was Team 1135, Whitney High Shmoebotics. It took them a while to get going but they did well in the end.
Christopher H Husmann, PE
"Who is John Galt?"
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
Tank drive is the way to go, as a rookie team last year we can attest that it did wonders for us.
a) It is easy to assemble. Just attach the drill motor assemblies to a frame, add a sprocket and a few chains... voila!
b) It provides both power and precise control. Lets face it... CASTERS SUCK! How many teams last year with casters didn't have trouble making it up the ramp? Not many
c) Easy to add upgraded functionality. We just happened to add a servo gear shifter so we could be fast, or powerful.
Here is a pic of what our base looked like last year. Very simple square base with a two beams running in the center to hold the drills.
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
Unread 06-09-2003, 16:19
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
In my limited experience with those tires, I've found them to be resilient. Obviously, the wire mesh of the 2003 game was a special circumstance that was destructive to all sorts of tires.
Turned down on a lathe, those wheels seem to provide adequate, accesible traction. Also, they come in the kit and they're keyed.
--Madison--
...down at the Ozdust!
Unread 06-09-2003, 19:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
One more reason to go with extrusion is than you can slide the pillow blocks for chain tension adjustment. We would have been in major trouble without that. Another substitute is an adjustable or sring loaded idler sprocket to use as a tensioner if extrusion is not used.
You can also do the same thing with square tube but you woyuld have to have slots milled.
Unread 06-09-2003, 19:44
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
You could also make those same slots with a drill press and a Dremel. I would know; we've done it for OCCRA, which doesn't allow milling machines. I would only advise it on aluminum, though... we burned out a dremel doing it on steel.
Jeff Waegelin
Unread 06-09-2003, 19:47
Madison's Avatar
FRC #0488 (Xbot)
Well, that's precisely why I don't like extrusion. The fasteners aren't terribly secure and can slide all over the place inside the t-slots. When you need to keep things in line or in certain spots, extrusion makes it harder.
While you can tension chain easily by sliding things around, those same things sliding around during a match can throw chains. I have first hand experience with that.
--Madison--
Unread 06-09-2003, 20:27
You don't need a different material, just a stronger arm on whoever installs the hardware and a little Lock-Tite too.
Unread 06-09-2003, 23:39
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Originally posted by "Big Mike"
acctually, thats not entirelly true, when the aluminum bent on our robot, we unbent it, just fine, i mean, after 4 competitions, we replaced it, but it still held up for that long
The Slam Hammer's your friend..
http://www.chiefdelphi.com/forums/pi...gle&picid=3546
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 07-09-2003, 20:17
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
This is what killed us this season.
Never again.
Unread 08-09-2003, 13:38
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Helical Gears
One thing to keep in mind about the "ready made" chassis. 90° helical gears are MUCH less efficient than straight spur gears or even chains. Since we all have to play with the same motors and the same power sources, efficiency is the name of the game in FIRST robotics.
I would recommend for a rookie team to chain drive the wheels to an intermediate shaft and use the FIRST provided coupler to attach the Bosch Tranny/Motor to the end of the intermediate shaft.
MattB
902
Unread 08-09-2003, 14:29
Adam Y.'s Avatar
Adam Y.
no team (?????)
They are resilient just make sure you are:
A) Really careful in modifying them
B)Make sure those tires do not become damaged.
Once the tires become damaged they are really just shot. The rubber on those things disintegrates fairly easily.
Actually the first season I was in the robot rolled off the table. The only thing that was wrong with the frame afterwards was that the wheels were off a bit but that was due to our innept drilling skills more than dropping it off a table. Plus I am pretty sure reading about using a torsion wrench to tighten the nuts which I am fairly certain that not a lot of teams do.
Unread 08-09-2003, 15:31
Madison's Avatar
FRC #0488 (Xbot)
For this reason, I'm also trying to make replacing the wheels a simple process. In fact, as I have it, you can replace the entire wheel/key/axle/sprocket assembly with a new one.
Well, in addition to the fasteners sliding around, another problem is pulling them straight out of their slots by tension. Overtightening them risks making this happen more frequently.
--Madison--
Unread 08-09-2003, 18:58
Matt Reiland's Avatar
'The' drive behind the drive
We had the same problems as everyone else with the extrusion and T-slots so we make it a habit of using t-nuts to prototype with then when things are where we want them drill through the extrusion and bolt the piece where you want it.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 08-09-2003, 19:10
Adam Y.'s Avatar
Adam Y.
no team (?????)
We ended up tapping the ends of the extrusion and attaching everything from there.
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
Preseason project AdamT General Forum 4 09-09-2002 00:52
project box archiver 2000 2 23-06-2002 23:01
physics project SharkBite General Forum 10 03-03-2002 22:06
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
