Go to Post Basically, it just doesn't matter. - Mark Pettit [more]
Unread 09-09-2003, 11:30
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 716 single speed
Unread 09-09-2003, 11:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I like that a lot. It looks very robust yet efficient and compact. It does look like the output sprocket was rubbing on the side plate though. Why did that happen? Also, where did you find the gear that is mating with the Chiaphua and what are it's specs. Thanks.
Unread 09-09-2003, 15:51
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I used the CIM motor with a 14 tooth gear to mesh with the gear train. This year's motor was used in the dual speed transmission so I bolted on the 2002 CIM (Atwood, Chiapua, see text on motor in picture). Several people at Riverrage commented on my 'magic' gear mesh with this demo.
The circular marks on the main plate are the result of chain stretch, chains falling off and chain wrapping around the sprockets. Carefull atention to chain tensioners during break-in could have avoided this, but what the heck, we just keep driving until they need tensioners!
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
