Go to Post An explanation of the reasoning behind design decisions will almost always result in a more thorough understanding of the solution than analysis alone can obtain. - Travis Covington [more]
Unread 09-09-2003, 19:50
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Sending Data
Ok, I'm almost done w/ my PBASIC Editor, and I'm just wondering...how would you send the code (in MFC)?
I've created a thread, and it doesn't have any problems.
I've been looking at how roboIDE sent the code, and if anyone can just translate these from Linux to Windows I would be set (I don't know any *nux programming):
read(fd, data, bytes);
I know the "read(...);" function reads the data from a port...but I'm not sure of the equivalent of it in Windows.
write(fd, data, bytes);
Save as "read(...);"
close(fd);
I've attempted "CloseHandle(...);", but it throws back a error.
int openSerial(char *port){
   int fd;
   struct termios tios;
   fd=open(port, O_NOCTTY | O_RDWR | O_NONBLOCK);
   if(fd<0){
     sprintf(lastError, "%s: %s\n", port, strerror(errno));
     return fd;
   bzero(&tios, sizeof(termios));
   tios.c_cflag = BAUDRATE | CS8 | CREAD;
   tios.c_iflag = IGNPAR;
   tios.c_oflag=0;
   tios.c_lflag=0;
   //satisfy read immediately.
   tios.c_cc[VTIME]=0;
   tios.c_cc[VMIN]=0;
   tcflush(fd, TCIFLUSH);
   tcsetattr(fd, TCSANOW, &tios);
   return fd;
<<EDIT>>: I know fd stands for file directive (I think anyways).
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 09-09-2003, 21:51
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: Sending Data
File Descriptor. I can't help with your actual question, though, .. sorry
Brandon Martus
e-mail
Unread 10-09-2003, 13:11
AKA: Eric Hansen
Re: Re: Sending Data
Thanks Brandon I talked to Rob last night, and now I only need help on the last code section. read() = ReadFile(), write() = WriteFile().
<< Edit >>: The stuff below bolded is what I don't get:
   if(fd<0){
     return fd;
   tios.c_oflag=0;
   tios.c_lflag=0;
   tios.c_cc[VTIME]=0;
   tios.c_cc[VMIN]=0;
   return fd;
Y!: synsoflife
Unread 10-09-2003, 16:39
Happy Birthday! rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
You're trying to mix POSIX and Win32. The two are NOT compatible and probably never will be, knowing MS. Instead, I'd recomend you grab code snippets out of RoboGUI, as it also has the ability to tokenize and send directly to the RC.
-Rob
Unread 10-09-2003, 16:41
AKA: Eric Hansen
-Rob
Ok, thanks. I've been able to get most of the code to compile without error though (not been able to actually send though, not tested that far). I've been looking through both RoboGUI and RoboEMU, and RoboGUI I thought had some sending code (and apperently I'm right, woo hoo!).
Again, thanks.
Y!: synsoflife
Unread 10-09-2003, 22:48
Umm Errr...
If i remember correctly, there is an MSDN article on serial port communications, with code samples.
<edit>
or maybie not. I can't seem to find the article. I know im not crazy. Im pretty sure i saw it at one time or another.
</edit>
1139 Alumni
Unread 11-09-2003, 14:46
AKA: Eric Hansen
I've got my program 99.9% running without problems. Only problem I'm having right now is having it not close when it cannot connect/send data to a specific port.
If you would like to see my code for it (it'll be a big thing to post on CD), IM, PM, or e-mail me.
Y!: synsoflife
Unread 11-09-2003, 16:05
Umm... more details, please. What is/isn't closing that shouldn't/should be? Are you talking about the file handle? Or the program itself.
/me=
Unread 11-09-2003, 16:28
AKA: Eric Hansen
/me=
Sorry. Here's what happens:
I open a file that has the default code for v2 of PBASIC that Innovation First supplied us, and goto Run->Download (which downloads the code). When I do that, what happens is that it shows two message boxes saying "Error getting serial port status" (which I can pin-point where the main problem seems to be). Then after I click OK twice (once for each message box), the program itself closes.
(I know this may be a bunch of wasted typing, but I hope that it clears it up as much as possible)
Y!: synsoflife
Competition Scouting pauluffel Scouting 31 09-01-2003 00:34
Robot Scouting Database archiver 2001 10 24-06-2002 03:00
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
Possible Configuration to keep things cheap archiver 1999 8 23-06-2002 23:03
Distribution of data soap108 Scouting 4 24-12-2001 09:23
