Go to Post I always tell newbies that if you build a great team the great robots will follow. - Wayne C. [more]
Unread 10-09-2003, 02:18
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
precise measurements in Inventor
I recently began working with Inventor to try integrating 3D modeling into our design process with the students.(a humble attempt to get ahead for 2004)
1. is there a way to use more precise measurements in inventor?
i'm an autocad guy, so i'm used to inputting precise radii, or using specific line lengths. inventor seems to be set up to use a more simple sketch style of design. how do i make more precise parts using inventor.
2. can i import 2d drawings from autocad directly into inventor?
this way i can use a more familiar platform like autocad to make 2d sketches then manipulate them in inventor.
3. can inventor create tool paths for a cnc mill?
programs like ideas and pro-e can create paths that will go directly into my cnc milling machine, can i do this with inventor?
thanks for any help.
Anthony Lapp
Team Lead --> 857 Superior Roboworks
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 10-09-2003, 07:14
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
Re: precise measurements in Inventor
There are two ways(that I know of) to do this: first you can use the precise input tool under View->Toolbar->Precise Input, or you can draw the basic shape then use the general dimension tool(under sketch) to specify its size and relative position.
Can't help you with that one, have you tried the “Insert Autocad File” button located under the sketch menu?
Anthony Lapp
In my CIM class we exported Inventor files to *.sat files then used MasterCAM to create the tool paths. I wouldn't recommend that though cause MasterCAM is pure evil.
Unread 10-09-2003, 11:00
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Sarah answered this pretty well. Using the general dimension tool, along with various constraints, makes making precise sketches much easier. For drawings that you'd use in machining, there's a whole other function of Inventor that you can use to dimension parts and assemblies.
Yes, but it's limited in its functionality. Particularly, AutoCAD drawings don't retain the same sort of adaptivity that sketches created in Inventor have. Extruding them into solids can be difficult, as well.
Whenever I've had to transfer anything from an AutoCAD drawing to an Inventor part, I've found it easier to remake the part in Inventor. Once you get the hang of the workflow, it's a very fast process.
No, not yet. There may be a plug-in available that handles this, however. I'm not familiar with anything, though, because I've never had immediate access to a CNC machine.
Anthony Lapp
Team Lead --> 857 Superior Roboworks [/b][/quote]
--Madison--
...down at the Ozdust!
Unread 10-09-2003, 11:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What was the keyboard command for general dimension?
Unread 10-09-2003, 13:46
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
the letter "D" is the keyboard shortcut.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 12-09-2003, 15:02
AKA: Anthony Lapp
thanks
some good suggestions here.....but still some problems.
everything i read says that inventor should be able to open any autocad 2002 files. when i try to open a dwg inventor says its an unsupported operation. is this because i use the edu version of inventor? does anyone know someone to call in regards to this? autodesk seems to offer help but their tech support isn't free.
Anthony Lapp
RobotOpen
Unread 12-09-2003, 15:53
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Import
If you have version 6 or newer there should be an icon under the "2d Sketch Panel" that says "insert autocad file". Then from there you have to go through a few more windows I believe.
Also make sure that under "Tools--->Add-Ins.." that you have all the translators turned on.
These are the only things I can think of.
Purdue Alumni
Cummins, Inc.
Cybersonics 2003 Autodesk Inventor Submission petek Inventor 6 07-03-2003 12:11
inventor plugin Lev 3D Animation and Competition 0 05-01-2003 22:53
Autodesk Inventor Award 2002 Digo Inventor 1 24-03-2002 12:07
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 31-12-2001 08:59
