Go to Post The game hint is never late. Nor is it early. It arrives precisely when it means to. - Oblarg [more]
Unread 06-02-2002, 16:21
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
Rotating Light - not rotating :-/
Is anyone having trouble with their light? Is it common for the light to stop spinning?
We are a rookie team, and don't remember seeking people with "still" lights in the past, but our light only likes to spin "sometimes".
Sometimes we need to give it a "kickstart" and sometimes it just chooses not to spin at all. We didn't modify anything... So far all we did was mount it on a block of wood so It can stand up while we test our bot. Thanks in advance..
Unread 06-02-2002, 16:29
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
yeah, we had that problem too, but then it went away. just push it a bit, and it should work. i'm not sure how our's got fixed, but it works now.
Unread 06-02-2002, 17:00
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
problems (light)
We also seem to have a very unique problem with our light as well. Apparently it is absent. We are still waiting for the parts from FIRST. Is anyone else waiting too, or should we be worried?
Unread 06-02-2002, 17:20
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
They sent the first shipment of lights they got in to rookie teams. All we can hope is that we DO get ares in the next 2 weeks. obviously we don't have ours either.
~Adam
Unread 06-02-2002, 17:45
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
No light yet here.
Last year the light was intermintit, but I think that was a wireing problem.
Check to make sure the wires are all securly fastened. They may be loose and hitting may knock the wires into a compleate circut.
Viva Olancho!
Unread 06-02-2002, 18:21
srawls's Avatar
srawls srawls is offline
#0122 (Nasa Knights)
srawls is an unknown quantity at this point
Send a message via AIM to srawls
Another thing to check for on the light is to make sure that the screws/bolts holding it to the robot are insulated from the metal on the light. We had this problem last year, and our whole robot frame was grounded. We didn't realize it till a judge at nationals caught the problem and told us to fix it. So, that probably won't cause the problem you're having, but be careful about it anyway.
Oh, we don't have our light either
Stephen
Unread 06-02-2002, 18:44
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
Wiring is fine and it is isolated away from the robot.
Light stays on, it just doesn't spin. Looks like the motor is binding or something. Will probably take it apart and put it back together.
Seems more like a poor manufacturing issue.
Unread 06-02-2002, 20:14
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
If the light only occasionally stops, it could be because of a low battery. Otherwise, we've not had any trouble.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 06-02-2002, 20:53
Pamela's Avatar
Pamela Pamela is offline
Half the JVN,All theTaste
Pamela has a spectacular aura aboutPamela has a spectacular aura aboutPamela has a spectacular aura about
Send a message via AIM to Pamela
When your light stops, does it just stop spinning or does the light stop shining also? Because if it just stops spinning, there is a problem with the light, if the light turns off occasionally you might want to check the battery, the wires, the breakers, and look on your controller interface to see if there are robot errors.
~Pamela, Alumni of 166 and 229
Unread 06-02-2002, 21:03
Brian Savitt's Avatar
Brian Savitt Brian Savitt is offline
#0056 (ROBBE Xtreme)
Brian Savitt will become famous soon enoughBrian Savitt will become famous soon enough
Send a message via AIM to Brian Savitt
We had that problem last year, honestly all we did was hit it on the top and sides when it stopped rotating and it worked...I dont know if you will be as fortunate as we were but its worth a try....
Brian Team 56
Unread 06-02-2002, 21:16
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Last year our light (the same as this year) quit turning in the middle of a match. The motor fried. FIRST gave us a new one, but it looks like there may be a quality issue here.
One other thing to look for is the infamous 255 max limit for PWM1 or PWM2 in your control code. That little gremlin can bite you. All PWM output values should be limited to 254 or less.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 06-02-2002, 21:34
Anton Abaya's Avatar
Anton Abaya Anton Abaya is offline
None #0419 (Rambots)
Anton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura about
Send a message via ICQ to Anton Abaya Send a message via AIM to Anton Abaya
ours stopped rotating last year.
that's cuz i disassembled it and didnt put it back properly. (oops? )
-antoninny
Unread 06-02-2002, 21:44
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
This year when we pulled out last year's robot our light wouldnt rotate. We have never had problems before. I connected it directly to a battery and it still wont rotate. There must be a problem with the lights themselves.
Unread 07-02-2002, 05:41
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
I agree with the quality issue..
On a full battery on relay 8 (always on) the light turns on and SHINES fine. Sometimes you gave give it a nudge (technical term) and it will spin. Other times it will just sit there, shinning and mock you..... " No I will not spin.."
Unread 07-02-2002, 13:32
aka Scott White aka Scott White is offline
#0555 (Montclair Mounties)
aka Scott White is on a distinguished road
We are not a rookie team, this our second year, and we just got our light and accessories today, so teams that haven't got them yet should be recieving them real soon.
The 3 magic ingredients are
Trust, Love, & Magic.
"We brake for broken speed controllers"
I love the the smell of melting speed controllers in the morning...
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
Lights on our robot (in addition to the rotating light)... archiver 2001 1 24-06-2002 01:02
rotating light archiver 2000 1 23-06-2002 23:06
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
Please help me with the size of the rotating light!!! bigqueue Technical Discussion 5 21-01-2002 09:40
