Go to Post Either you have it hooked up wrong, or you have the Battery of the Gods. Probably filled with Mountain Dew... - nighterfighter [more]
Unread 16-09-2003, 19:51
John JediMaster's Avatar
John JediMaster John JediMaster is offline
#0019 (Big Red)
John JediMaster is an unknown quantity at this point
Send a message via AIM to John JediMaster
How could I learn AutoCAD?
Hey since I want to be able to do more during this years build season, and I want to learn it period. Does anyone know where or how I could learn AutoCAD?
Unread 16-09-2003, 20:19
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I learned to do a few basic things in AutoCAD a while back in an engineering class at the local community college. It was hard to start but easy once you got going. One word fo advice, don't try cheapo free CAD programs. While some are still very capable, all are very difficult to use.
I would recommend if you have a community college nearby, you take a class on AutoCAD there.
I will be having to learn Inventor myself in a few days. YAY!
Unread 16-09-2003, 21:05
Mark Hamilton's Avatar
Mark Hamilton Mark Hamilton is offline
Belphegor made me do it.
#0108 (SigmaC@t)
Mark Hamilton will become famous soon enough
Send a message via ICQ to Mark Hamilton Send a message via AIM to Mark Hamilton
I am actually learning AutoCAD at the local community college right now. I enjoy the class, and if you want to learn AutoCAD it's probably the way to go. The professor has taught us a lot of things that aren't in the books. If you can't take the class, however, the book we use is pretty good, it's called Discovering AutoCAD 2002, you can probably get a decent understanding if you follow it.
Retired member of Team 108
Unread 17-09-2003, 09:06
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Personally, I feel your best bet will to be to go to google and search for "AutoCAD Tutorial".
Even if you are a beginner, find one that labels itself as Intermediate, and pay attention.
Follow the tutuorial step by step, then repeat it without the tutorial on-screen. Refer back to it if you have to, but try and do as much on your own.
Then do another one... repeat the process. After the second one is done, repeat the first without the reference on-screen.
This method will make you likely forget what the tutorial said and see if you remember the steps, not the verbatim. If you aren't satisfied with your results, don't feel bad. Grab a beginner tutorial and do the same steps as above.
Everyone learns differently, I can not garuntee that this method will work for you, but I don't see any possiblity of it hurting.
Unread 17-09-2003, 09:11
Electrical Engineer
Rookie Year: 1995
I suggest that you check out the following tutorials that were created specifically for FIRST:
http://usa.autodesk.com/adsk/servlet...112&id=1047962
Mike Betts
As easy as 355/113...
Unread 17-09-2003, 11:17
Umm Errr...
I often learn things well by buyign a book. Have you checked you local bookstore?
1139 Alumni
Unread 17-09-2003, 11:28
Jason Rudolph Jason Rudolph is offline
Alumni of 168
Jason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud of
Send a message via AIM to Jason Rudolph
As I have just finally had to learn autocad myself, I can suggest a book called "Mastering AutoCAD" by George Omura. It takes you from square one to being an expert (it's also 1600 pages). After about a week of sitting down with it, I had learned enough to make basic drawings quite well (and I have only gone through 1/3 of the book, if that). It has lots of information, and it is easy to find and understand that information as well.
Unread 17-09-2003, 11:31
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Exclamation A suggestion ......
I would suggest that if you really want to be productive in this years design, you learn Inventor instead. Your team should have at least one copy lying around and the tutorials are pretty good.
The reason I say this is that many of the parts you need to create models of design ideas are already available in Inventor. If you use Autocad, you have the learning curve of the software to deal with plus the gazillion hours of time it will take to draw all of the common parts.
FIRST CAD Library
Ed Sparks
MECH TECH FRC-3959
Unread 17-09-2003, 12:01
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
taking ED&G at college ... LOL.. kill me now, I have no idea what I am doing in Auto CAD..... best wishes!
Unread 17-09-2003, 15:56
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Something our team did was aproach companies that sell the product and do training as well. We had a company offer us two free seats in their training class. They already had the class paid for by others and had empty seats. Free is a good thing
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 17-09-2003, 16:21
Umm Errr...
Re: A suggestion ......
FIRST CAD Library
Everyting in the First Cad Librabry is available in several formats, which autocad supports. I would focus on learning autocad, and then learn inventor. Invertor is really not that complicated and can be learned pretty well in a matter of days. Autocad on the other hand is much more in depth and complicated. I see them as 2 tools that complement each-other, not learn one or the other. Some things are better suited for autocad, some for inventor.
my 2 cents
1139 Alumni
Unread 17-09-2003, 17:32
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
If you have to pick, I'd say learn Inventor. While Inventor does not have a whole lot of seats out there in comparison to AutoCad, the way it works is the direction most major CAD systems are going. I find it very easy to switch back and forth between Inventor (robotics) and Catia5 (work). (I don't want to talk about Catia4, the memories are still too painful) Even Unigraphics is slowly getting more parametric and sketch based. This is not to say that there is no place for AutoCad. I still fire up my version of R14 when I need to answer questions using just wireframe and surface stuff. But I find I'm doing it less and less.
The key is to learn a reputable parametric solid modeler. Once you've figured out how to work in one, the rest are easier.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 17-09-2003, 17:48
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
hey heres my 2 cents and as i am a high school student, that had to learn autocad on his own after being taught inventer, i got a few things to say...
~Autocad is great for schematics, arcitechural drawings and 2D drawings.
~Inventor is great for any 3D modeling and drawings, it has many user friendly interfaces and options, and once you get the hang of it you can keep up with new versions
~Autodesk, the new versions seem to change alot and if you do not use it very often, and get placed to use a new version you havent seen before you may be a little frightened, but i have seemed to find AutoCad 2000 to be one of the best Autocad programs, espically i got a free edicational version of it.
Mike
-Michael Dessingue
Unread 17-09-2003, 18:30
Matt_Kaplan1902's Avatar
Matt_Kaplan1902 Matt_Kaplan1902 is online now
#DecadeofDelicious
FRC #1902 (Exploding Bacon)
Matt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond repute
Send a message via AIM to Matt_Kaplan1902
AutoCAD
I am a junior in HS. This year I am taking a drafting class and an engineering class wich teaches rhino. Both of these are 3 year programs but I took them mostly to be able to do more with my team. Some people I now that are older have said that a community college is a great way to learn how to do AutoCAD. I would love to learn about Inventor but I havent gotten the opportunity to find out more info on how to. Just my 2 cents.
Team 1902: 2007-??, Mentor
Team 108: 2002-2005, Student
Unread 18-11-2004, 10:56
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
Re: How could I learn AutoCAD?
IF the site loads, (and that's a big IF), you could try this site. the if comes in where Scitobor 617 (Alan) may have forgotten to connect his server to the web. We (Team 617) have made a site with various tutorials on it. Hope it helps!
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Where can I learn some mechanical before build season John JediMaster General Forum 7 23-09-2003 20:27
Successful Due to Affluence? indieFan Chit-Chat 4 31-05-2003 14:48
Would you like to learn how to sign? OneAngryDaisy General Forum 0 05-03-2003 20:11
AutoCAD Viewer Gadget470 OCCRA 2 25-09-2002 03:19
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 31-12-2001 08:59
