Go to Post Some of the best team captains I've seen have been from rookie teams. - Conor Ryan [more]
Unread 13-07-2003, 00:59
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Thanks for the replies... here are some answers:
Jim - you would be suprised, I can be a space case sometimes.
Cory - thanks for the nitpicking, it is needed. I will make the change and wait for other stuff that may need updates.... they I will re-post it after a while. Since it is in "public domain" it needs to be right. If you or anyone else finds errors, please let me know.
Tytus - a CNC end mill. Our high school machine shop made the parts that needed CNC'ed on a Haas machine, I believe.
John - thanks for the support. The good thing about the machine dogs is that they are permanent... you don't have to worry about them once they are made. Sure, they take a little more time to machine as opposed to putting in dowels, but it is worth it. As for 2004... it will have more recution and reduce parts. We would've liked to have about 25% less rpm on the output shaft.
Mike - it would be great to see people build these in their free time. Better yet, improve upon the design and post your findings. (one of my favorite quotes: "If I have seen further, it is by standing on the shoulders of giants." - Issac Newton). Take what we have done here and improve it... that is what Newton meant.
Sanddrag - the gears actually don't cost that much. Keep looking around for suppliers. These gears can be purchased, off the shelf, for about $90. Two sources that I used are Martin Gear (20 pitch, purchased through Applied Industrial) and Rino Mechanical (32 pitch, purchased direct).
Joe - good for you. Designing a gearbox in two days is not easy. However, quickness in design can cause errors, just as you made errors while criticising our design. We did not use a 24 or 32 tooth gear. Also, I am not sure why you say "what took so long?" Do you have your design posted on the web? If so, please reply with a link. Also, I trust that you are a good designer, but it would be helpful if you wrote with more clarity. It's somewhat hard to understand what you are trying to say.
Again, thanks for the comments... keep them coming.
Andy B.
Unread 13-07-2003, 01:31
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Andy thanks for the words of encouragement, i was thinking about changing some of the gearing ratios around and just tinker a little to see what i can do with the output. i am wondering if i make it so the output has higher torque and less rpm's, what it may do on the voltage input, if it may draw more or if it could cause a stall on the motor or what may happen...
~Mike
"Make Failures and LEARN By Them, DO NOT Let Your Own Failures, Get You Discouraged..."
-Michael Dessingue
Unread 13-07-2003, 02:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I was a little off. I actually came up to $205 for each gearbox using gears from Berg and SPI. My 20 pitch gears were in the following tooth counts 16, 40, 60,20, 80. I plan to use bigger gears than you did for some slightly different ratios. That 80T gear is like 75 bucks alone from Berg. I'll check with your suppliers if and when my team builds this thing.
As for your note about the CNC machines, HAAS are wonderful. They are such a joy to work with and so user friendly. (I am just starting out on one).
Unread 13-07-2003, 08:18
Matt Reiland's Avatar
'The' drive behind the drive
Originally posted by sanddrag
It's not just the time. It's the money. Otherwise my team would be building one right now. We figured it would be about $250 for just gears for one gearbox. Of course that was with some slightly different ratios that we came up with.
Sanddrag, take my advice and go to your local Motion Industries and get the Martin Gears. We were buying them from Small Parts & Boston and their prices were over twice as expensive as Motion Industries plus they were in stock.
Andy, great job on the prints, to show the level and detail as well as a complete model in Uni-Graphics surely took a great deal of your time, and I for one appreciate it.
I might tinker around with it a bit and see if I can incorporate any of the features we used this year. One thing I really want to test out is the spring loaded shifting linkage with the hobby servo. If I can get it to mount and work on the side of the tranny I will post it to give an alternative to pneumatics. Gear job of eliminating the wire-edm parts, it opens up the design to many more teams.
Along the same lines to teams out there: looking through the design it appears you could make most of the parts on a regular mill with a digital readout. I tried making one of the gears with the pocket dog mates at home on my machine (which is CNC) but I did it by hand with a rotary table and you can do pretty well without the CNC. I can't wait for one of our schools (Troy Athens) to have their CNC machine at school making parts for us this year.
One thing I am not really clear on is the mount of the drill motor. We had to make an aluminum carrier so we could screw into something (Also made a fantastic heatsink too!) , how are yours mounted in the 2003 gearbox? Also love the carrier on the CIM motor, fantastic idea.
Great tranny, ohh so small too.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 13-07-2003, 08:37
Originally posted by dez250
[b]Andy thanks for the words of encouragement, i was thinking about changing some of the gearing ratios around and just tinker a little to see what i can do with the output. i am wondering if i make it so the output has higher torque and less rpm's, what it may do on the voltage input, if it may draw more or if it could cause a stall on the motor or what may happen...
~Mike
Mike,
If you change the ratios to lower the RPM and increase the torque this will only help out the motors even more from stalling and they will draw less current than if you geared it up for higer RPM's. Keep in mind teams out there you can build this tranny exactly to the print and add any output stage to the wheels that you want, up or down. We reduced ours by 3:1 last year with 6" brecoflex sprockets and it was pretty much too hot to handle in high so we will also go a little lower for 2004 which will give you even more torque.
Unread 13-07-2003, 12:39
Matt, thanks for that, i want sure if dropping the rpm's would cause a stall or if i had it backward, which i guess i did. This will be a fun project and looks to be quite an interesting one.
~Mike
-Michael Dessingue
Unread 13-07-2003, 14:24
Let's remeber that CNC's do not make parts FOR you; they make parts WITH you. A lot of newcomers to machining (not that Matt is by any means) get into the habit of saying "Oh, let's just do it on the CNC." Well, it's not that simple. Everyone should realize that a great deal of programming goes into making even the simplest part and a lot of thigs could be done more simply and quicker on a good 'ol manual.
Unread 13-07-2003, 14:59
Excellent point sanddrag, even though my machine is CNC in the lab where we build the robot it is fully manual with a Digital Read Out.
However most CNC machines can do things that aren't very easy to do manually like complex curves, speed, and allowing for duplicate parts once the program is created. The best way to learn is to do it manually and have knowledge and respect for the machine, then as a convenience move to CNC if you have it. Up until just recently our schools had no metal machining facilities and they finally went and bought an EMCO with a full shroud. I am going to see it next month.
Unread 14-07-2003, 09:44
Matt,
Thanks for the comments.
This points out one thing I forgot to include in the write-up. Mounting the drill motor was not as easy as the prints show. We altered the drill motors a bit in order to make them mountable. Very carefully, we threaded the two holes on the front face of the drill motor for M5x0.8 screws.
In order to thread these holes, we started out with a regular M5x0.8 tap to begin cutting the threads. Then, we switched to a "bottoming tap" (which is the same tap with the end tip grounded off) and finished the threads. We did this in so that the tip of the tap did not hit the motor windings. Also, when we threaded these holes, we used grease on the tap so that any chips would cling to the tap... we did not want chips getting into the windings.
It was kinda tricky, but it worked fine. We did not have any drill motor mounting "issues" once they were installed.
There probably is a better way to do this... 226's way of making a separate piece to hold the drill motor is more of a "for sure" way to go, and I am always for making things better.
Andy B.
Unread 14-07-2003, 09:58
WernerNYK WernerNYK is offline
AKA: Chris Werner
FRC #0190 (Gompei & the HERD)
WernerNYK is a jewel in the roughWernerNYK is a jewel in the roughWernerNYK is a jewel in the rough
Send a message via AIM to WernerNYK
Oh so true... We made custom aluminum 72-tooth sprockets on the manual mill; each one probably took less than an hour to manufacture from start-to-finish.
Don't underestimate what can be done on a manual mill with just a little ingenuity
-Chris Werner
"Production Manager"
BattleCry@WPI
Team 190 - WPI & Mass Academy
Est. 1992!
Team 871 - Former team leader
Unread 15-07-2003, 23:33
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Andy -
As always, your transmission design and plans are superb.
The approach we took with the drill motors this year was to use two short #10 machine screws in the face plate of the motor mount (i.e. they projected through the small holes in the face of the motor, similar to the plastic pins in the original drill transmission). To retain the motor against the face plate, we used small "J-hooks" made out of 1/4" drill rod that ran from the face plate, along the sides of the motor, to the square notches at the rear of the motor housing. The screws/pins prevented rotation, and the J-hooks prevented lateral motion of the motor. It was very easy to fabricate, and we didn't have to try to tap the holes in the face plate of the motor (I was really concerned about getting chips into the windings), and proved to be pretty robust (we never had a motor torque out of place, and we beat on it pretty hard).
I will post a set of drawings in a few days, as soon as I get them cleaned up. We updated our transmission design for the 2003 larger drill motors, and had good success with it in Annapolis. The design is still bigger and clunkier that the Teknokat transmission, but doesn't require CNC for fabrication (for those of us still limited to manual mills and lathes ).
-dave
Unread 16-07-2003, 12:56
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
real men hold the back side of their motors...
I like your design, Dave.
2 things. First, I like that it does not require customizing the motor (something that I think is just good FIRST practice if you can manage it). Second, I like that it holds the back side of the motor.
We ended up holding the motor with a plate that fit on the boss on the back side of the motor.
As I said in the subject heading, real men hold the back side of their motors... ;-)
Joe J.
Unread 19-09-2003, 11:34
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Shift Shaft
The ubergeeks are currently fabricating the parts to try and practice with this gearbox design. The biggest question that our team has at the moment is what do you have the shift shaft connecting to with the thread at M3x0.7
We do not have the this dye nor does the other machine shop that is helping. Is there a specific reason for using this thread.
Great design and my students are very excited about seeing this gearbox work.
Matthew
Team 1028
Ubergeeks
Unread 19-09-2003, 11:58
Re: Shift Shaft
Matthew
Team 1028
Ubergeeks
This part of the design is shown in the picture on the front of the white paper, but it is not detailed in the prints. The only reason I specified an M3 thread was to keep with our common fastener practice of M3 or M5 metric threads. However, like your team, we did not have a M3 die. So, we used a #6-32 die.
We put a small bearing (1/8" id) and a #6-32 lock nut to couple to that shifter shaft. The lock nut wanted to back off after many cycles, so we drilled through the nut and threaded stainless steel "speed wire" to hold the lock nut in place.
Good luck,
Andy
Unread 19-09-2003, 18:23
Re: Re: Shift Shaft
Couldn't you have just jammed two nuts up together? Also, I'm not sure if they come in small sizes but there are these really cool nuts called crimp nuts where the top of them is smaller so it fits very tightly on the threads acting like a locknut but it is all metal, no nylon. They are used on aircraft I believe.
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
