Go to Post Gracious professionalism... otherwise, the program has failed. - Yan Wang [more]
Unread 06-02-2002, 20:29
Dima Dima is offline
Dima is just really niceDima is just really niceDima is just really niceDima is just really niceDima is just really nice
Send a message via AIM to Dima
Look in the gallery
Team 60 posted pictures of thier robot that is pretty much done i assume (exept for spares) you can go to thier website to look at more pics.
What can i say other then THIER ROBOT IS GORGEOUS
(i can't spell)
Unread 06-02-2002, 21:00
Brian Savitt's Avatar
Brian Savitt Brian Savitt is offline
#0056 (ROBBE Xtreme)
Brian Savitt will become famous soon enoughBrian Savitt will become famous soon enough
Send a message via AIM to Brian Savitt
I saw their robot earlier in the day...I'm confused what do you think it does???I have no clue, but it still looks nice as always...
Brian Team 56
Unread 06-02-2002, 22:41
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Inference
Brian Team 56
If I had to guess?
I'd say that it moves in between two goals, latches onto them, and pulls them inward toward the robot.
Simultaneously, the goals are lifted up off the ground onto those large arms. The arm, as you can see, is attached to a drill motor, and can rotate. This can have some advantages.
They've got a four-motor drive train, too. It uses the Chiaphua's geared down to the drill motor's 'high' setting, and all four motors feature a pneumatically driven, 'on-the-fly' transmission.
Very nice.
--Madison--
...down at the Ozdust!
Unread 06-02-2002, 23:22
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Unhappy Be Afraid... Be very afraid...
As if the shifting on the fly isn't enough, having a 4 motor drive train will only make it worst. If you look closely at the gear shifter, you can tell how much different the ratio will be. I suspect with 4 motors, it can achieve a top speed of more than 13~14 ft/s... Mean while, an extremely slow speed of 1~2 ft/s to push forward in low gear...
I expect the rotating arms aren't finished... There will be something extra powered by the seat motor at the end of the arm. With a drill motor controlling the arm, it can easily get goals and spin them around with about 20 robots attached to it. Well, actually, it will be strong enough to rotate 2 goals, and probably a robot attached to one of the goal.
I suspect the two yellow pole at the and of the arm are pivots for some really really strong claws. Because it doesn't make sense for the seat motor's flexible shaft to be exposed like that. However, it could be really likely that the seat motor will be used to raise up the goal. Ah, that make sense... a hook like device, or some latches that will attach to the goal pole that will slide up and down on the yellow pole, and the seat motor attachment under it will be pushing the latch/hook up and down on the pole.
Hmm... the hooks/latches should be pointing forward or some how rotating, so they can grab both goal by running straight into them... Or else they will have to grab one goal at a time and rotate the arm to grab the other one...
Be afraid... Be very afraid...
Unread 07-02-2002, 01:58
OMFG Ken
Look at thier website they have like 10 pics there!
Unread 07-02-2002, 02:13
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Where are they?
I saw ONE picture of this year's robot (on the front page) and a bunch of last year's in the picture galery. Is that what you were looking at? If not, where did you find 10 pictures of this year's 'bot?
Unread 07-02-2002, 03:33
Dare to Live!
The links are:
http://www.team60.net/02pics.htm
http://www.team60.net/02pics2.htm
As you see on the second page, they have the finished hooks attached to the arm...
I KNEW those hooks are going to look like that before I even saw the second page of pictures.
Very nice looking robot from team 60. (Again!)
Unread 07-02-2002, 03:38
I knew you knew!
Can you say AS USIAL? (good looking)
Unread 07-02-2002, 07:39
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Very impressive...
Look to Kingman to win at least one more bit of plastic to their trophy collection.
Very nice design.
Joe J.
P.S. I wonder how well or poorly it turns? Lot's of traction with 4WD. Maybe they have to shift to low gear to turn?
Unread 07-02-2002, 17:03
Turning
can you hear them breakers poping? i think that is why they have the arm rotate they pretty much need not to turn
Unread 07-02-2002, 19:23
mnkysp6353's Avatar
mnkysp6353 mnkysp6353 is offline
no team (Bagel Bytes)
mnkysp6353 is an unknown quantity at this point
Send a message via AIM to mnkysp6353
I hope i will be seeing some equally exceptional robots from all of the members on this board.
Unread 08-02-2002, 09:41
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Team's 60 - 2 speed transmission
Question; Please explain, if they shift on the fly how do they avoid the gears from shearing off when they go from low to high and vice versa?
Unread 08-02-2002, 13:28
ReijiH's Avatar
ReijiH ReijiH is offline
ReijiH is an unknown quantity at this point
Send a message via AIM to ReijiH
change of color theme?
If i remember correctly, wasn't Bionic Bulldog's color theme blue and yellow the last two years? Just wondering why they changed it to yellow paint and red anadization.
Think medical technology's perfect? Well Think again
"March 4th, 2002: A man walked into his Doctors office in Sacremento, California. He told the Doctor, "Doc, it hurts when I go like this!" The Doctor said "Well, don't do that!" The man later died of cancer."
Unread 08-02-2002, 19:39
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Shift on Fly?
From the looks on the pics i dont think they will be shifting on the fly....but they will be able to shift....
If i'm seeing this all right i bet they come to a stop to shift...and the pneumatic moves the gear back and some sort of software code runs through a "shifting" program that will moves the gears back and forth until they align in the high gear position or the low gear position...
But, i could be wrong
Purdue Alumni
Cummins, Inc.
Unread 10-02-2002, 01:37
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
That robot is awsome looking. It has a great concept. I was wondering though. We got a new type of seat motor gear box to convert from x to y axis this year instead of the old flex cable from previous years. I assumed that everyone got this. I see that 60 is using the flex cable, did anyone else get that this year?
FIRST image gallery. evulish General Forum 17 25-05-2003 18:14
FIRST photo gallery Amanda Morrison Chit-Chat 2 23-05-2003 19:15
picture gallery Mike Schroeder CD Forum Support 5 23-09-2002 00:20
There's a Who-am-I gallery, use it! Ken Leung CD Forum Support 20 17-03-2002 21:23
new picture gallery Brandon Martus General Forum 9 17-07-2001 15:52
