Go to Post and as you can see, all rumor threads lead to silly, loads of silly - JaneYoung [more]
Unread 22-09-2003, 21:42
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Doubble-wishbone Crab fender
Unread 22-09-2003, 21:44
xplod1236's Avatar
xplod1236 xplod1236 is offline
None #0818 (Genesis '02)
xplod1236 will become famous soon enoughxplod1236 will become famous soon enough
Send a message via AIM to xplod1236
That's a great idea, but would you use it on a robot?
Unread 22-09-2003, 22:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I have to admit I have NEVER seen that combo before.
Unread 22-09-2003, 22:44
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Tytus,
I deffinatly give you a A+ for creativity.
Some problems that i see, your robot "chassis" is going to be very small, becaus those suspension stuts are going to take up a big chunck of space. also how are you going to rotate each pod? i noticed that each drive module is powered by one shaft out the top. are you going to attach 1 drive motor to run all those pods or are you going to have individual wheel w/ a motor?
Thats a really good idea, run with that
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 22-09-2003, 23:00
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
You need for the wheels in each module to be pointing in the same direction to work, obviously. It appears as if you planned on using belting that's common to two or more modules to achieve that.
I hope you've considered timing belt as an option or something else than won't slip. Slipping, over time, will throw off the alignment of your modules relative to one another.
More importantly, I don't understand how that belting is supposed to remain attached to a crab module that's going up and down on a suspension. Perhaps a better explanation of how the belting would interact with the frame and other modules would reveal how this works?
--Madison--
...down at the Ozdust!
Unread 22-09-2003, 23:08
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
Why do you need a suspension? For more tire contact at all times? Surface area doesn't affect traction.
Unread 22-09-2003, 23:12
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
im thinking of going in the Half-shaft direction instead of the Kevlar for Propultion, the steering could be all linked for simplicity or all indivdual steeper-motors for some crab,Quadrosteer,and other wikid cool tricks. Please Feel free to throw your own ideas in there, it would look kinda like a starfish with 4 points, i know Its dard to Keep track of the scale of things in 3DS-MAX
Unread 22-09-2003, 23:19
Madison's Avatar
FRC #0488 (Xbot)
Yes, it does. Search around CD for a bit and you'll see that we've beaten this into the ground. In fact, there's a whitepaper that shares some experimental results that were ascertained by a SPAM member (or family member, if I recall correctly.)
Don't ignore deformation.
--Madison--
Unread 23-09-2003, 01:38
In Hibernation
#0481 (DART)
mmkay, here goes:
Originaly posted by you, M:
If your wheel is a smooth surface (i.e., aluminum, two wheel chair wheels), double the area will do nothing to aid your traction at all. It will increase by a factor of 1.
So you are saying that on a smooth regular surface, the surface area doesn't matter.
Ok, so how about an irregular surface where the tire and and surface can intermesh, say on carpet?
From the whitepaper,: When the surface area went down the friction increased
Wait, is this saying that not only did the traction not go down, it went up?
Hmmm....
Unread 23-09-2003, 01:43
Madison's Avatar
FRC #0488 (Xbot)
I'm sorry, but didn't you just establish a correlation between surface area and traction? It seems to me that you did. Never did I say that increasing your surface area increases your traction because that's simply not true in all cases.
However, it can be true and has been true in FIRST in the past. How do I know? I designed a drivetrain that was, apparently, stronger than 250 or so others and it was based entirely on deformation and the meshing of irregular surfaces.
--Madison--
Unread 23-09-2003, 01:58
Traction can go both ways with surface area. Rock crawler 4x4s (and sand vehicles) air down their tires for a bigger footprint. More suface area and more traction. But some 4x4 mudders (and snow vehicles) use really skinny tires so they can sink into it and get a bit on what's on the bottom rather than float over on top. I know this isn't really about traction on FIRST robots but it was the first example I could think of. There are just so many variables involved that it really depends on the exact materials and the exact situation.
Traction is such a complex issue that it's really not worth debating about because everyone is right and wrong, just in different ways. There are so many factors involved: tread, interlocking surfaces, surface area, friction, composition of both tractive surfaces, stickyness, softness of both surfaces, gravity, and that's just the beginning of them. Nascars have smooth tires on a very smooth surface but get incredibly good traction. 4x4s have very aggressively treaded tires on very uneven surfaces but get incredibly good traction. There is a different kind of tractive surface that works best for every terrain. And it being the best is only in the eyes of the operator. There are way too many things that make up traction for any one person to be right about what works the best for everyone. Just do what you think works good and let everybody else do what they think works good.
Problem solved.
Unread 23-09-2003, 20:31
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Very impressive Tytus.
Only downside I see is it's size. If you wanted to put that on a FIRST bot you might want to shrink it down, so that you have more room available for electronics and any other mechanisms.
Keep up the good work
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 23-09-2003, 20:46
AKA: Ty
Its very hard to keep track of scale with 3ds-max its not in measuring units, its in standard numbers with no realitivty
Unread 23-09-2003, 21:09
The reason I think it looks big is because I'm imagining a wheel the size of the wheels in the kit as the wheel in your design, which is what, 6 or 8in diameter?
Hopefully you can build one sometime, I'd love to see a bot with that on it.
Ryan
Unread 23-09-2003, 21:40
AKA: Ty
the skyway wheels are about 9.5 inches in diamater, I know itS WAY off scale
pic: Coaxial Lego doubble-wishbone crab CD47-Bot Robot Showcase 7 10-12-2003 12:10
pic: Crab Concept 6 CD47-Bot Extra Discussion 13 14-11-2003 22:03
pic: Tytus Coax Crab Fender CD47-Bot Extra Discussion 9 28-09-2003 00:17
pic: Tytus Crab Drive lego model CD47-Bot Extra Discussion 11 08-09-2003 18:36
pic: 217 Gen 2 Crab Module Section view CD47-Bot Robot Showcase 2 28-04-2003 18:26
