Go to Post Jenny - thanks for not beating any of our team members up with their own MOE sticks! That must have taken some willpower to hold yourself back! - Mr MOE [more]
Unread 06-02-2002, 21:00
J. Stofflett's Avatar
J. Stofflett J. Stofflett is offline
FRC #0123
J. Stofflett has a spectacular aura aboutJ. Stofflett has a spectacular aura aboutJ. Stofflett has a spectacular aura about
Need help with PBASIC Code
We are working on refining our drive train on our robot and have encountered a problem with overloading the 30 amp breakers supplying power to the wheels. We are using a four-wheel drive setup with a tank drive to steer. We have changed the gear ratio once and will be changing it again but time is running out. We are very weak in the area of programming and wonder if anyone could help, is it possible to reduce the power output to the motors by changing the default code in the robot controller? We are running the 2 big black motors using speed controllers from PWM-1 and PWM-2. We have played with changing the default to tank steer with one joystick, using the changes found on Innovation First site. This gives us a sense that we can successful change the code and up load it to the controller if someone would be able to supply use with the changes that need to be made. Any suggestions or resources you could provide would be very helpful
PBASIC 2.5 Code on the RC Goya Programming 2 12-01-2003 17:00
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
2003 PBasic default code from Innovation First ttedrow Programming 0 06-01-2003 11:18
emulationFIRST (aka PBasic emulator) Matt Leese Programming 5 30-06-2002 12:06
BuzzWriter - PBasic Assistant archiver 2000 0 23-06-2002 22:58
