Go to Post I, as a programmer, always strive to have the entire robot operate with as little driver input as possible. Those pesky humans.... - dellagd [more]
Unread 23-09-2003, 17:43
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
as i helped run the IRI scoring system and match system, i learned about the problems with the 2002 and prior controllers trying to work with the 2003 arena comp ports. the bot will work like normal under controller mode, where your drivers drive it, but before the match starts, through all of autonomous mode, the station (drivers booth) light will flash and auton mode wont work on your bot. It has to do with the controller software, and how the 2003 OI's are designed to work with auton, as the prior ones weren't made for that purpose.
~Mike
-Michael Dessingue
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
