Go to Post Like many researchers before me, I look and read about what my peers are doing and developing, and then incorperate the best of them into my ideas or change my focus because of them. - Wetzel [more]
Unread 25-09-2003, 19:30
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
Originally posted by Stud Man Dan
The suspension would have been of great use on this years game.. it would have kept all 4 wheels in contact with the surfaces at all times.. while battling on the edge of the ramp ( at carpet and the top ) many times whoever got most traction could win.. no matter how strong the drive train. This sort of suspension would be of great gain in that situation
actually, the easiest way to do that would not be a suspension per se, but merely have one of the axles on a pivot of some sort. If you don't quite understand what i'm getting at, take a quick glance at the back two wheels of this robot. They pivot freely so as to always keep surface contact.
There were a couple robots that i remember at nationals that had similar designs (can't remember numbers though). It could be done with a swerve drive like this (since it is coaxial, you shouldn't run into chain or motor alignment problems). The advantage of a pivoting system like this is that it will always keep the weight equally devided among the four wheels. A traditional suspension will keep all wheels on the ground, but different wheels will apply differing amoungts of force to the ground (making it less efficient.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
pic: Coaxial Lego doubble-wishbone crab CD47-Bot Robot Showcase 7 10-12-2003 12:10
pic: Crab Concept 6 CD47-Bot Extra Discussion 13 14-11-2003 22:03
pic: Tytus Coax Crab Fender CD47-Bot Extra Discussion 9 28-09-2003 00:17
pic: Tytus Crab Drive lego model CD47-Bot Extra Discussion 11 08-09-2003 18:36
pic: 217 Gen 2 Crab Module Section view CD47-Bot Robot Showcase 2 28-04-2003 18:26
