Originally posted by skyman9000
MIPS is million instructions per second
Direct access to I/O means that you can access the pin inputs and ouputs for the controller and read and/or manipulate their values directly.
Interrupts are what a controller uses to perform other tasks outside the main program loop. The processor goes off for a while to process the interrupt and comes back to the main code where it left off (Could be used for sensor polling etc).
You should grab a good book on microcontrollers if you are really interested. It should explain all this stuff. Or just do a search on google.
Thanks.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
