Go to Post 256:1 gear reductions provide surprisingly little torque once the gears have failed. - Kevin Sevcik [more]
Unread 28-09-2003, 01:20
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Originally posted by djcapelis
So interrupts effectively facilitate good function jumps then?
I'm not sure exactly what you mean by a "function jump", but the way I understand it, when the system encounters an interrupt, it executes a predefined function, and then goes straight back to where it left off.
At the machine level, the system pushes the program counter (the address of the instruction it was at before it received the interrupt) into a stack, stores any important information, and jumps to the code of the function that should be run on the given interrupt. Once the interrupt's code has completed, the original address is popped out of the stack, and all of the aforementioned important information is put back in its original place.
I hope I got that all right. If not, please correct me.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
