Go to Post I hate mini-bots. - Gdeaver [more]
Unread 28-09-2003, 12:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
4 pole motor?
How does a 4 pole (brushed) motor work? Are there simply two positive and two negative leads to which power must be applied? Or is there a complex control circuit that sequences the power distribution? Thanks
Unread 28-09-2003, 18:26
without more detail I would think you have it right, two sets of magnets and two armatures energized at the same time, or slightly offset.
I dont think Ive ever seen one myself.
stepping motors use two fields, but they dont have brushes.
Unread 28-09-2003, 22:28
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
actually, i think you only need one set of magnets.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 29-09-2003, 07:30
Sanddrag,
Usually when you are referring to the poles of a motor, you are referring to the number of magnetic circuits with in the motor. If you opened a "four pole" brushed motor, you would find four distinct windings on four cores of the armature. As the motor turns, the brush assembly supplies current to each in turn to provide the motor power. (Of course, current is supplied to the windings to make north and south poles and the polarity is determined by the brushes and commutator.)
The more poles in a DC motor, the more even the power output, much like the addition of cylinders in a car engine. Under load, this makes a big difference. If you examine one of the drill motors, for instance, you will see more than four poles.
Unread 04-10-2003, 17:24
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
Cool Just A-Wondering (Yes, the BRUTEFORCE is back for the season)
Originally posted by Al Skierkiewicz
Sanddrag,
Ok so you're saying that the motor will work more efficiently under load, but does the addition of poles in the motor have any effect on the total output power or RPM of the DC motor? [keeping in mind that it still has the same voltage]
---Just wondering, something i have wondered about for awhile.
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 04-10-2003, 18:21
Unlike an AC motor, the number of poles does not have a direct effect on output power or RPM nor can you say it is more efficient. The number of poles are optimized for motor function. You can say that the higher the number of poles, the greater the starting torgue or starting RPM under load. In general, the higher the number of poles the greater the output power at low RPM. There are always tradeoffs, cost goes up as you add windings, construction becomes more complicated, balance is more difficult to obtain, etc. The motor designer must choose from their box of tricks which variables to optimize and which to suffer with.
three pole electric motors Solace Motors 10 11-08-2003 23:56
Thermal Protection archiver 2000 1 23-06-2002 23:27
Window motor tape archiver 1999 4 23-06-2002 22:04
Gear/Sprocket Help Joseph F Motors 3 18-03-2002 07:48
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
