Go to Post The JVN/Karthik segment should have more than enough spontaneity for everyone - Matt Krass [more]
Unread 04-02-2002, 19:44
rdmendola rdmendola is offline
rdmendola is an unknown quantity at this point
Question coupling
Would a Jacobs chuck be considered legal as a coupling for our drill motors?
Unread 04-02-2002, 19:52
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
sounds interesting, what is a jacobs chuck?
Unread 04-02-2002, 20:02
It's a drill chuck.
Unread 05-02-2002, 08:03
The Jacobs pattern chuck is the Basic Drill chuck with a Key that turns an outside gear to cause the jaws to extend through an opening which is smaller than the jaws, causing them to get closer as they come forward, gripping the drill.
If you found it in Small Parts, go for it. It wasn't in the kit, and it's not in the additional Hardware List.
Beware the dreaded slippage to which grippers of round things are subject, both in rotation (round and round) and along the axis (in and out).
The trantorque coupling is a workable idea of a similar nature that was part of the kit in years past, and may still be available from SPI.
Unread 05-02-2002, 10:15
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
hehehe, sorry.. my bad...
I didn't realize that was the name for s standard drill chuck..
Thanks...
Unread 05-02-2002, 11:37
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Re: coupling
Only if you bought it from small parts or made it from legal materials.
Unread 05-02-2002, 14:55
That seems to fit the definition of a fastener to me.
Unread 06-02-2002, 14:39
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
I thought shaft couplers were on the AHL this year in unlimited quantity. I don't have the rules handy and we're not using any so I haven't had to stay current on that item so I may be mistaken on that.
To my mind if it's joining two shafts (the motor output and what ever else you're hooking up), and the coupled items have the same rotational velocity, what you have is a shaft coupler and it doesn't matter what other names it may have.
But beware of the problems previously mentioned. (rotating in the chuck or sliding in and out) You might want to use a hexagonal shaft for the input to whatever else you're connecting to the motor. The chuck will grip this better than a round shaft.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 07-02-2002, 11:48
Keithicus Keithicus is offline
#0920 (Lancers)
Keithicus is an unknown quantity at this point
From the Additional Hardware List:
Shaft Couplings - Any Amount, Any size
Interesting question. I would have to say depending on your use. In other words, it would have to connect 2 shafts.
coupling Bosch & Atwood motors caffel Motors 10 28-05-2003 16:00
Coupling the Chiaphua & a variable Drill output Jeff Sharpe Motors 9 13-01-2003 20:21
SPI Wheel coupling cracking like crazy! archiver 2001 4 24-06-2002 00:56
Motor coupling archiver 2001 19 23-06-2002 23:35
3.5x3.5 coupling? ahecht Technical Discussion 1 05-01-2002 23:36
