#11
I checked the specs on their webpage:
http://www.microchip.com/1010/pline/...8520/index.htm it has FLASH for program memory, and EEPROM space for program variables. that means your program can store information as its running, that will be there next time you powerup - so you could save things like your yaw rate sensor zero reading, or any other variables you need to fine tune your control algorythms. the 7.2 'backup' battery is probabally what powers the controller (most likely regulated down to 5V or 3.3). Lke someone else said, this is probabally so the controller doesnt reset if your motors draw a large current spike. We will have to see how it all works together. BTW, the EDU kit last year, everything ran off a 7.2V battery. Last edited by KenWittlief : 01-10-2003 at 19:43. |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| How do you connect the speed controller fans? | Iain | Electrical | 7 | 31-01-2003 07:05 |
| visibility of robot controller? | davidzhang | Rules/Strategy | 5 | 26-01-2003 01:11 |
| Q&A Discuss: Are specs available on the new motors/mounts? | CD47-Bot | Extra Discussion | 3 | 15-01-2003 19:39 |
| Motor specs | kmcclary | Off-Season Events | 4 | 26-10-2001 22:41 |
